Acessport ???? - Page 2 - Subaru WRX Forum
post #16 of 20 Old 05-04-2010, 08:56 PM
It removes emissions related codes, nothing more. It will simply no longer display a CEL if your O2 sensors are unhappy and/or disconnected.
post #17 of 20 Old 05-04-2010, 10:43 PM
midian879 is an unknown
alright. Is there any other information i should know before tuning up to this map? any problems etc? like will i be able to use all the stock lines that go to my stock turbo for the vf39? I just want to make sure I know as much as possible before i upgrade.
midian879 is offline
post #18 of 20 Old 05-04-2010, 11:09 PM
02WRXbugeye's Avatar
02WRXbugeye is an unknown
Well I was running the vf39 map for my 06 after I got the turbo and sti intercooler and I was having issues of overboosting in 3rd gear. I found that it might have been the cause of a pill needing to be drilled bigger in one of the air hoses but I got a pro tune before finding out and the tune fixed everything.
02WRXbugeye is offline
post #19 of 20 Old 05-05-2010, 07:00 PM
so would you recommend a pro tune or buying the accessport and using the vf39 map? also if a protune would be better does anyone know of a good one in maryland except IAG **EDITED**
post #20 of 20 Old 05-05-2010, 09:22 PM
A good tune is always superior to a general purpose map. Please avoid shop bashing. if you have a problem with the service rendered to you or someone you know, take it elsewhere.
