i have a 02 wrx wagon and i am looking at buying a cobb accessport v2 and i was reading up on cobbs site and read the requirements for stage one and for stage two and it says that you only need a turbo back exhaust to run the stage 2 ..... i have a full exhaust, header, up, dp and tbe(catless) plus a pnp intake manifold, turbo inlet tube, walbro 255 fuel pump and a 2 row grimmspeed radiator.... i know the radiator has nothing to do with it but my question is am i gonna be ok to run the stage 2 with more than what they recommend or am i gonna have to run somthing diff????
ok thanks guys i was thinking i needed a protune but i wasnt 100% sure!! do you guys know how much a tune would run me? and do i have to buy any programs or tuners or will the shop have all of that?
If you're in Wisconsin you could come down to P&L Motorsports P&L Motorsports - Home here in Chicago. They charge $199 per hour on the dyno. They've told me they can do a basic Stage 2 tune in that hour.
There is a $60 dyno inspection fee so they can look over your car and make sure there are no issues or vacuum leaks. Since your car is an 02 I would recommend this.
If you have not purchased the Cobb Accessport yet, they also do opensource tuning on the WRX's now. I personally prefer the Cobb b/c you can go back to stock quickly without having to bring the car back to the tuner.
Also check into 555 Motorsports in Chicago. I have started talks with them that should happen while Im deployed. The tuners name is Mat, an awesome guy and will answer any question you have.
