3/16" mod - Subaru WRX Forum
post #1 of 6 Old 06-27-2005, 07:53 PM Thread Starter
berg8992's Avatar
berg8992 is an unknown
3/16" mod
can someone explain the 3/16" mod to me? Is it replacing the plastic 3 prong vac connector attached near (to) the wastgate with a larger one?
berg8992 is offline
post #2 of 6 Old 06-28-2005, 07:02 AM
silver04's Avatar
silver04 is an unknown
Send a message via AIM to silver04 Send a message via Yahoo to silver04
Try looking into these links, they'll explain it and tell you how you can do the mod if you choose to:
http://www.scoobymods.com/forums/showthread.php?t=4595
http://www.scoobymods.com/forums/sho...ght=3%2F16+mod
silver04 is offline
post #3 of 6 Old 06-28-2005, 07:32 AM
Cosmo's Avatar
Images: 15
Don't bother. I haven't seen where it makes any difference.
Cosmo is offline
post #4 of 6 Old 06-28-2005, 08:37 AM
gingertooth is an unknown
leave it alone. it's a waste of time.
gingertooth is offline
post #5 of 6 Old 01-30-2006, 10:06 PM
bjpeppers is an unknown
I have done this and I have also seen some data log graphs from others who have done this. You defintely get a little bit more boost in first gear and a little sooner. You also hold boost a little longer in all gears. You tend to get a rise to a little more than usual and then it drops for a second and then comes on strong again for a little longer. I can't see where this slight change can make a difference and I have read about more people being happy with it than upset. The only thing that you have to watch is that the plastic connector you buy can handle the heat. A good suggestion is to go to Home Depot or something and pick up the same thing but brass. This way you know it will stay in tact. The only risk you run with the plastic 3/16 mod is if the connector cracks and you overboost.
bjpeppers is offline
post #6 of 6 Old 01-31-2006, 03:41 PM
IBAUCLAPlaya's Avatar
When Tim Bailey from PDX tuned me, he put in the 3/16" restrictor since I couldn't hit peak boost and bam, 17.5 psi. Just my .02
IBAUCLAPlaya is offline
