20g turbo question? - Subaru WRX Forum
post #1 of 11 Old 08-12-2010, 02:01 PM Thread Starter
rexowner04 is an unknown
20g turbo question?
I just got a 20 g turbo from a friend of mine, says it has about 1500 hundred miles on it. What all do I need to do to my car before I can put it on? What can I use to clean the turbo up a little? Its got some coolant residue on it. Thanks a bunch
rexowner04 is offline
post #2 of 11 Old 08-12-2010, 02:17 PM
is your car stock?
post #3 of 11 Old 08-12-2010, 02:40 PM Thread Starter
my car is stock but all I have is cat back
post #4 of 11 Old 08-12-2010, 03:38 PM
you'd need an up-pipe, downpipe, 700cc or better fuel injectors, upgraded fuel pump, upgraded intercooler, tune etc.
post #5 of 11 Old 08-12-2010, 05:35 PM
And pray the tranny doesn't go boom.
post #6 of 11 Old 08-12-2010, 10:13 PM
The tranny will be fine depending on driving habits. But like Matt suggested all those parts, plus a 3 port BCS, and maybe, just maybe an intake. Check out my profile for a parts run down, I run a 20G and love it.
post #7 of 11 Old 08-12-2010, 11:01 PM
You're nowhere near 20G ready. Aside from supporting mods (intake, downpipe, intercooler, injectors, fuel pump, up-pipe, motor mounts, clutch, and suspension and brakes that can support this power.) being an issue, a 20G is going to be the deathblow to not only your transmission but your engine as well.
True enough, but he is more likely to break it attempting a 3rd gear pull than a 1st gear launch with that amount of power.
post #8 of 11 Old 08-13-2010, 06:53 AM
Complete truth here!...when my trans blew it was third gear that broke (although I rarely launched on the stock trans/green combo)
post #9 of 11 Old 08-18-2010, 10:33 PM
Johnnys WRX's Avatar
Johnnys WRX is an unknown
I have an 02 wrx and i have all the supporting mods for 20g but the tranny is my most fear what would you gies suggest I move to so I dont break anything
Johnnys WRX is offline
post #10 of 11 Old 08-18-2010, 10:41 PM
There are plenty of options out there. Whats your budget? Theres the STI 6-spd, then a plethora of 5spd options (PPG, Par, Albins, RA, LGT gears, MFactory, DS1....and maybe some more). My car just got an Albins gearset put in 1-5 helical cut, stock ratio. It will hold my 20G and then some (the shop said, and from my research seems adequate). But I havent got to drive the car since the build.
post #11 of 11 Old 08-19-2010, 02:20 PM
okay ### i dont think im gonna stop at 20g im gonna run it for a while ### its just sitting around
