-   -   20g turbo question? (http://www.wrxtuners.com/forums/f52/20g-turbo-question-29280/)
rexowner04 08-12-2010 03:01 PM
20g turbo question?
I just got a 20 g turbo from a friend of mine, says it has about 1500 hundred miles on it. What all do I need to do to my car before I can put it on? What can I use to clean the turbo up a little? Its got some coolant residue on it. Thanks a bunch
basco 08-12-2010 03:17 PM
is your car stock?
rexowner04 08-12-2010 03:40 PM
my car is stock but all I have is cat back
basco 08-12-2010 04:38 PM
you'd need an up-pipe, downpipe, 700cc or better fuel injectors, upgraded fuel pump, upgraded intercooler, tune etc.
RcrsWetDream 08-12-2010 06:35 PM
1 Attachment(s)
And pray the tranny doesn't go boom.
newtothegame 08-12-2010 11:13 PM
The tranny will be fine depending on driving habits. But like Matt suggested all those parts, plus a 3 port BCS, and maybe, just maybe an intake. Check out my profile for a parts run down, I run a 20G and love it.
brfatal 08-13-2010 12:01 AM
[quote=rexowner04;248985]my car is stock but all I have is cat back[/quote]
You're nowhere near 20G ready. Aside from supporting mods (intake, downpipe, intercooler, injectors, fuel pump, up-pipe, motor mounts, clutch, and suspension and brakes that can support this power.) being an issue, a 20G is going to be the deathblow to not only your transmission but your engine as well.
[quote=newtothegame;249002]The tranny will be fine depending on driving habits.[/quote]
True enough, but he is more likely to break it attempting a 3rd gear pull than a 1st gear launch with that amount of power.
basco 08-13-2010 07:53 AM
[quote=brfatal;249004]True enough, but he is more likely to break it attempting a 3rd gear pull than a 1st gear launch with that amount of power.[/quote]
Complete truth here!...when my trans blew it was third gear that broke (although I rarely launched on the stock trans/green combo)
Johnnys WRX 08-18-2010 11:33 PM
I have an 02 wrx and i have all the supporting mods for 20g but the tranny is my most fear what would you gies suggest I move to so I dont break anything
newtothegame 08-18-2010 11:41 PM
There are plenty of options out there. Whats your budget? Theres the STI 6-spd, then a plethora of 5spd options (PPG, Par, Albins, RA, LGT gears, MFactory, DS1....and maybe some more). My car just got an Albins gearset put in 1-5 helical cut, stock ratio. It will hold my 20G and then some (the shop said, and from my research seems adequate). But I havent got to drive the car since the build.
Johnnys WRX 08-19-2010 03:20 PM
okay ### i dont think im gonna stop at 20g im gonna run it for a while ### its just sitting around
