-   -   2005 wrx (http://www.wrxtuners.com/forums/f52/2005-wrx-33533/)
damonjy19 01-28-2013 07:02 PM
2005 wrx
Hi i have a 2005 wrx it has 140,000 miles. I was wondering if this is to many miles to do any performance mods? Thank you
pzr2874 01-29-2013 05:34 AM
That is quite a bit of miles.
Is everything up to date (maintainence wise)?
brfatal 01-29-2013 07:19 AM
Suspension, no. Power, yes.
detrails01 01-29-2013 05:48 PM
I would say if youre not doing large performance mods( i.e. huge turbo running 20+ lbs of boost) and want a little extra power out of your car, maybe stage 1, shouldnt be problematic. There are plenty of people in that mileage range that are running multiple power upgrades, yet just driving with a little more tlc.
I would make sure all scheduled maintenance is completed ( timing belt, fluids etc). Tune up, run a compression test and make sure the motors healthy, use good oil and change it on the dime and dont drive it like you stole it. :)
man show 01-30-2013 08:17 PM
If all factory suggested maintenance is up to date and the compression test is good, you could probably get away with a turbo back exhaust (and an up pipe in your case as a safety mod) and Stage 2 tune of some sort, but I wouldn't go much beyond that.
Two links you should check out:
[url=http://www.cars101.com/subaru/subaru_maintenance.html#2000Maintenance]Subaru maintenance schedules and new car break-in period- 2000 through 2009, links for 2010, 2011...[/url]
[url=http://forums.nasioc.com/forums/showthread.php?t=533787]Unabomber's Manifesto - NASIOC[/url]
