Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-On Tech (EJ205 2.0L '02-05 WRX)
Old 08-22-2009, 11:57 AM   #1 (permalink)
Reputation: The New Kid is an unknown
2005 engine swap question
I have an 05 wagon and want drop an 07 sti engine in it
Wil I have any problems
Thanks
Old 08-22-2009, 12:27 PM   #2 (permalink)
Reputation: Modena1230 is an unknown
Send a message via Yahoo to Modena1230
You will need the sti wire harness because the sti is drive by wire. I've heard its very difficult to swap.
RM
Old 08-22-2009, 12:42 PM   #3 (permalink)
Do I need the sti tranny or could I run it on the 5 speed
It will fit though right
Old 08-22-2009, 01:59 PM   #4 (permalink)
Not only the wiring harness, if I recall since one is drive by cable and one drive by wire you need to change pedals also. Im not sure about the transmissioni.
Old 08-22-2009, 02:13 PM   #5 (permalink)
Reputation: Chase is known to be trustworthy and helpful Chase is known to be trustworthy and helpful Chase is known to be trustworthy and helpful
Putting an STi bottom end on WRX heads is a much more desirable choice, it makes the swap easier. Search hybrid block on here. You could continue to run your 5 speed either way, you just need a WRX clutch between them.
Stage 2 Cobb OTS map 2004 STi
Soon to be Stage 1 2001 Corvette
Old 08-22-2009, 03:46 PM   #6 (permalink)
Well the problem is I have blown engine the top and bottom are no good so I need a whole engine and I want 2 upgrade to 2.5 sti engine and I found 2007 one for good price so dats y I am asking the questions and only thing I am really worring bout is if I am going need the transmision but chase it doesn't matter and from ### has been posted it going be diffcult swap but needs 2 be done
Old 08-23-2009, 01:14 PM   #7 (permalink)
oldfartracer's Avatar
Reputation: oldfartracer is more helpful than not
You can't drop an 07 sti motor into a wrx with a ton of work. Harnesses, pedals, ecu, are just a few of the things needed. I think you have swap the motor harness and the body harness to get the STI ECU to work.
Buy the STI motor, sell the heads, get wrx heads. This would make life a lot easier.
Old 08-23-2009, 08:54 PM   #8 (permalink)
ok i just talk to the guy its not a sti engine its 2.5 wrx engine but it does not come with ecu has every thing else including wiring harness can i use my old ecu or no
Old 08-23-2009, 09:16 PM   #9 (permalink)
No.
It might work if you swap out the intake manifold and TB from the 05.
Old 08-23-2009, 09:39 PM   #10 (permalink)
so i have to buy a ecu for a 07
Old 08-23-2009, 09:42 PM   #11 (permalink)
btw thanks for the help i really need to her running again
