08 WRX squeak sound - Need help - Subaru WRX Forum
 1Likes
  • 1 Post By boo-key
post #1 of 6 Old 06-05-2014, 02:59 PM Thread Starter
Ian Metry is an unknown
Hello everyone, I have a 2008 WRX wagon with basically stock everything except for a Cobb intake and cobb downpipe and cat back exhaust. I use the Cobb accessport and have stage 2 with 91 octane gas.
My issue is, the other day I was driving and during 5-10psi of boost i heard a squeaky sound. 2 days later, it is random and is from 3-15psi. Usually it would start at 5 and around 8 or so it would stop squeaking and just be the normal turbo spooling sound. Currently, instead of the squeak dropping it continues to squeak all the way through the pull.
I have read it could be a clip on the tubing for the turbo, or the intercooler. I tried the water and soap test to see if there is any clear sign of a leak, but no luck with that.
About a week or two ago I put on new AC and alternator belts, I don't think those could be the squeak, but I have no idea.
Please let me know any thoughts of what it could be and any easier way of diagnosing by myself.
Thank you!
Ian Metry is offline
post #2 of 6 Old 06-05-2014, 03:20 PM
Brockton's Avatar
Take the coupler from the intercooler to the throttle body off, take off the rubber boots on each side of it, throw them away, and re-install it. See if that clears it up.
Brockton is offline
post #3 of 6 Old 06-05-2014, 05:01 PM Thread Starter
Thank you, I am not familiar with the vehicle very much as i bought it recently. To remove that coupler, do i need to pull the IC or can i get to the coupler without pulling it out.
https://www.youtube.com/watch?v=5SRG-vzoCwM - is this basically what i need to do?
post #4 of 6 Old 06-05-2014, 06:13 PM
Brockton's Avatar
Yeah, its really easy. If this isn't the source of your problem, it will be eventually, you don't need a new hose though, taking the rubber ends off of your stock hose is all you need to do.
Brockton is offline
post #5 of 6 Old 06-05-2014, 07:04 PM Thread Starter
Thanks, it worked!
post #6 of 6 Old 06-06-2014, 12:23 AM
boo-key's Avatar
Originally Posted by Ian Metry View Post
Thanks, it worked!
I think some rep is in order here :thumbup:
Glad your all fixed up now!
Brockton likes this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
