-   -   08 WRX squeak sound - Need help (http://www.wrxtuners.com/forums/f52/08-wrx-squeak-sound-need-help-50042/)
Ian Metry 06-05-2014 02:59 PM
Hello everyone, I have a 2008 WRX wagon with basically stock everything except for a Cobb intake and cobb downpipe and cat back exhaust. I use the Cobb accessport and have stage 2 with 91 octane gas.
My issue is, the other day I was driving and during 5-10psi of boost i heard a squeaky sound. 2 days later, it is random and is from 3-15psi. Usually it would start at 5 and around 8 or so it would stop squeaking and just be the normal turbo spooling sound. Currently, instead of the squeak dropping it continues to squeak all the way through the pull.
I have read it could be a clip on the tubing for the turbo, or the intercooler. I tried the water and soap test to see if there is any clear sign of a leak, but no luck with that.
About a week or two ago I put on new AC and alternator belts, I don't think those could be the squeak, but I have no idea.
Please let me know any thoughts of what it could be and any easier way of diagnosing by myself.
Thank you!
Brockton 06-05-2014 03:20 PM
Take the coupler from the intercooler to the throttle body off, take off the rubber boots on each side of it, throw them away, and re-install it. See if that clears it up.
Ian Metry 06-05-2014 05:01 PM
Thank you, I am not familiar with the vehicle very much as i bought it recently. To remove that coupler, do i need to pull the IC or can i get to the coupler without pulling it out.
[url]https://www.youtube.com/watch?v=5SRG-vzoCwM[/url] - is this basically what i need to do?
Brockton 06-05-2014 06:13 PM
Yeah, its really easy. If this isn't the source of your problem, it will be eventually, you don't need a new hose though, taking the rubber ends off of your stock hose is all you need to do.
Ian Metry 06-05-2014 07:04 PM
[quote=Brockton;456538]Take the coupler from the intercooler to the throttle body off, take off the rubber boots on each side of it, throw them away, and re-install it. See if that clears it up.[/quote]
Thanks, it worked!
boo-key 06-06-2014 12:23 AM
549 Attachment(s)
[quote=Ian Metry;456570]Thanks, it worked![/quote]
I think some rep is in order here :thumbup:
Glad your all fixed up now!
