-   -   05 WRX help (http://www.wrxtuners.com/forums/f52/05-wrx-help-33719/)
stevensnedd 03-12-2013 10:18 PM
05 WRX help
Hey guys, I just bought an 05 wrx and have some questions. the mods for it are:
Engine back exhaust (headers,up pipe, down pipe, and catback) - no name brand
boomba fuel rails
walbro 255 fuel pump
mishimoto bigger tmic
godspeed (I think) td05 big 16G turbo
unknow BOV
unknown stage 2 clutch
engine rebuilt 10k ago
I was thinking to put STi injectors on it, and get a custom map for it, since i have an upgraded turbo, and full exhaust on it.
Let me know what your thoughts and opinions are about it
thanks
basco 03-12-2013 10:57 PM
if that car doesn't already have injectors and a tune on it it shouldn't even run
man show 03-13-2013 08:51 AM
I didn't know Mishimoto made aftermarket TMICs - I know they make silicone hoses.
Sounds like you need injectors, a 3 port ebcs, a tune, and perhaps an intake or K&N drop in air filter.
Also, ditch the BOV (if it vents to atmosphere) and find a recirculating BPV.
The Stage 2 clutch might be an issue too. Generally, if you have a stock transmission, you should also have a stock (or stock equivalent) clutch or you risk breaking gears.
stevensnedd 03-13-2013 03:53 PM
[quote=basco;291648]if that car doesn't already have injectors and a tune on it it shouldn't even run[/quote]
you mean it shouldn't start, or I should drive it?
brfatal 03-13-2013 10:23 PM
Meaning you shouldn't even be turning the car on.
If it's a Godspeed turbo, then a new turbo is also on the list for purchases you need to make immediately.
stevensnedd 03-14-2013 07:22 AM
[quote=brfatal;291693]Meaning you shouldn't even be turning the car on.
If it's a Godspeed turbo, then a new turbo is also on the list for purchases you need to make immediately.[/quote]
Ive heard they weren't the best, I'd go with like a vf39 if this one dumps on me
pzr2874 03-14-2013 07:35 AM
Or a vf43 or a vf22 or a vf34
BLAZE2099 03-14-2013 08:33 AM
Why must you always skip the 30 Paul? It's a great turbo. A bit more rare, but still a good option.
stevensnedd 03-14-2013 09:09 AM
I don't really want to make a huge amount of power. I want the car to last a while and stay reliable, what's a good turbo for that?
pzr2874 03-14-2013 10:48 AM
Never really read up on the 30... Never any reason to.... I've seen more 22's and the others than I have 30's.
Anyone of the VF series chargers are fine for reliability. Get the one with the lowest possible miles and stick to one that is generally going to be easy to replace IF it ever goes out (for tune sake)
stevensnedd 03-15-2013 07:28 AM
could I use the cobb ap OTS map, for the 16g, even though its for a different brand turbo? would it be bad that I only have 93 octane in my area, and 91 is the only octane for that map?
brfatal 03-15-2013 08:24 AM
No....
stevensnedd 03-15-2013 01:18 PM
[quote=brfatal;291745]No....[/quote] to which question?
brfatal 03-15-2013 02:26 PM
Both.
For the record, one of my friend's shops had a Godspeed turbo explode on the dyno recently. Yes. Explode.
stevensnedd 03-15-2013 02:51 PM
What do you suggest I do? I can't get a new turbo right now so cut that out. I don't drive it daily, so what should I do for everything to run right? I can't get a custom (dyno) tune, so it'll have to be like an accessport custom map or something.
