04' WRX about to go under the knife.. - Subaru WRX Forum
post #1 of 21 Old 01-23-2012, 01:24 PM Thread Starter
pimmeh's Avatar
So i've done what i'l call "Mild modification" and tuning to my 04'. I've been daily driving the beast and i'm more than impressed about the HP gains i've made.
list of mods is as follows..
2004 WRX
AMSoil all around
K&N Typhoon
invidia Up pipe
HKS catless Down
Greddy full 3" cat back
Cobb APv2 "Stage 2"
Cobb Stort throw
Now my little TD04 is running like the wind and my injector cycle duty is...well higher than i like not to mention i have reached the limit of the stock fuel pump ect so i have began the process of acquiring some new parts...
Walbro 255 intank
tomei type "s" adjustable FPR (and additional required fittings)
06'STI TMIC with piping and BPV
as well as the remote line for my Oil pressure sender so i can monitor my oil loss as i think i have a decent amount of blow through.
so my questions are.
1- where should i mount the Tomei AFPR and will i require any additional parts? i already have the adaptors for the stock FPR's and the additional fittings but do i need additional fuel lines..ect?
2-best location for remotly locating an oil pressure sender? or advice on installition!?
3-is there any differance between my stock BPV and the 06 STI BPV that came with my TMIC? which on should i use?
4- The Tomei AFPR comes with and oil filled gauge. where the hell should i mount that? and idea's suggestions? also pictures would be awesome.
Basically i'm going to address all of my possible fuel issues so come this summer i can replace my lil TD04, stock injectors and slap a 3 port bcs on as well. if i am overlooking anything please let me know. there is a wealth of super knowledgable guys on here and i'de like your imput now as suppose to after i blow this F#$^%er up!
Thanks for your time,
Chad
pimmeh is offline
post #2 of 21 Old 01-23-2012, 02:13 PM
Can't help with the other issues. But....
3 - The STI BOV is the exact same as the WRX BOV in 2004-2007 MYs. Which would mean the 2002-2003 WRX has the same BOV as well.
post #3 of 21 Old 01-23-2012, 03:30 PM
I could run the sender off the rear plug on the top/back of the block on the passenger side by the turbo.. Normally I would say just plug in the sender where the stock pressure sensor is under the alternator, but if you're running remote you'll want a good spot to mount it, and there are plenty of them on the firewall. Make sure to use some sort of vibration dampening clamp (pretty much a rubber coated clamp) as they're pretty sensitive.
Something like this (even comes with a replacment tapped plug to use on that spot I mentioned:
Remote Oil Pressure Sending Kit - Gauge Installation Accesoiries
Also, don't use oil pressure as a means to judge how much oil you have left. Oil pressure dropping low should never be used to know when you're low on oil, basically it's too late if you're showing low pressure. Low oil pressure on a Subaru = smoked bearings. Just check it at each fill up.
That being said, oil pressure and temp are two of the best things to monitor.
post #4 of 21 Old 01-30-2012, 12:38 PM Thread Starter
pimmeh's Avatar
awesome i'm installing the sender tonight this will help big time. i actually was preping to use the most suggested locaton (behind the alt) but this will work way better. oh and i totally grabbed the Prosport remote setup. it comes with everything including the sending mounting rubber clamps ect. Oh and thanks for the heads up on the Oil Pressure's not being indicative of low reserve. Last thing i need is false confidance in my info and thus neglecting the regular checks!
pimmeh is offline
post #5 of 21 Old 01-30-2012, 12:42 PM Thread Starter
pimmeh's Avatar
Yup Thanks! i installed the STITMIC a few days ago and i just used my stock BPV. it saved me having to do more than undo a couple screws! all togeather the TMIC swap was super simple..
pimmeh is offline
post #6 of 21 Old 01-30-2012, 01:35 PM
Just wondering why you are replacing the FPR ?
post #7 of 21 Old 01-31-2012, 11:27 AM Thread Starter
pimmeh's Avatar
Basically i want to ensure the flow of fuel is never lean. the effency of my fuel pump is maxed as well as my fuel injectors are running at about 90-95% cycle duty. which means my self and pretty much everyone running the Stage two Maps on Stock injectors and fuel pumps are running the fuel system very near its maximim output. ie if anything goes wrong the engine will lean out and the chance of detonation becomes extremely high.
i've putchased a walbro which i'm actually installing tonight (just finished the STI TMIC and the sender unit for my Oil pressure.) but it's my understanding there is less benefit too simply replace the fuel pump with out adjusting the fuel pressure.
If anyone knows any differant please let me know... This is simply what i have found through my own research so if ANY HAS INSTALLED A ADJUSTABLE FUEL PRESSURE REGULATOR please let me know. i have some questions as well! hahahaha
anyways hope that answers that!
pimmeh is offline
post #8 of 21 Old 01-31-2012, 12:32 PM
It does, if you were going bigger an AVO would have eliminated the need for it (but to each their own)
Good luck
post #9 of 21 Old 01-31-2012, 01:32 PM
blk05WRX's Avatar
To help others that might run across this thread, here's a picture of where the oil pressure galley is, right under the throttle body. I run the remote sending unit. It's been two years without any problems.
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
post #10 of 21 Old 01-31-2012, 02:26 PM Thread Starter
pimmeh's Avatar
Good luck
Thanks! so are you refering to the AVO fuel pump? if so how would that eliminate the need for a AFPR? i realize that is not a requirement but is the AVO pump really that much better?
pimmeh is offline
post #11 of 21 Old 01-31-2012, 02:32 PM Thread Starter
pimmeh's Avatar
blk05WRX,
i would have loved thos pics last night when i did the install although after one beer and about ten minutes of humming my install ended up literally identical.
Thanks tho!
hopefully anyone looking to go down that road stumbles on this thread cause those are the best pics i've seen of the Gally plug local.
on a side note what is your idle oil pressure? running oil pressure? and do you notice that when you start the car the oil pressure takes untill its pretty much warmed up to settle??
Thanks,
Chad
pimmeh is offline
post #12 of 21 Old 02-01-2012, 05:54 AM
It's a stronger/more durable pump, the walbro's are junk and they are known to take dumps (maybe because there are so many of them in use, i'm not sure). What size charger are you wanting to put in there to nessesitate a FPR ?
post #13 of 21 Old 02-06-2012, 02:17 PM Thread Starter
pimmeh's Avatar
i've been lookin HARD localy for a used Ihi vf 39 or 43 but im not maiking much headway. if i am going to purchase a new turbo i'll lakely go with a Tomei Arms m7760. I totally realize the AFPR is not a nessesity but as i mentioned before i'd like to ensure i never have fuel issues.. what do u think?
pimmeh is offline
post #14 of 21 Old 02-06-2012, 02:21 PM Thread Starter
pimmeh's Avatar
BTW i reduced my injector duty cycle by 10% by simply adding the walbro (with the stage 2 Cobb map.)
pimmeh is offline
post #15 of 21 Old 02-06-2012, 06:24 PM
Look into the Blouch line of turbos. Last time I was looking around a turbos, Blouch was better priced than Tomei, but that was months ago. Just a thought.
