03 wrx bug eye - boost leak ? - Page 2 - Subaru WRX Forum
post #16 of 36 Old 04-23-2013, 12:54 PM
I don't know the ID on those lines. I have given a couple of these out to different members on here in the past.
They do have to be a specific size for the pill to work correctly.
With a 3port BCS... that whole portion is taken off (reason for a tune).
Hope this helps.
post #17 of 36 Old 04-23-2013, 01:39 PM Thread Starter
03bugeyeDude's Avatar
03bugeyeDude is an unknown
Hope this helps.
thanks, yeah Im taking all this into consideration, I wanna take my time and do this right
.... I'll keep you posted if I come across other issues..
03bugeyeDude is offline
post #18 of 36 Old 04-23-2013, 03:22 PM
Know what? Go get it from the dealer... takes the guess work out of the equation.
The pill is like $1.68 and the lines can't be more than $10-$12
post #19 of 36 Old 04-25-2013, 07:27 PM
*raises hand* pick me, pick me
post #20 of 36 Old 04-26-2013, 05:34 PM Thread Starter
Hey got caught up with work ... didnt have time to reply...
but anyways I did a quick test I installed a MBC (i know i know just temporary)
just to see if I would get some boost and I did
14-16 yikes, i tried a couple of times from 3rd gear and it would boost 14, 15, 16 unstable the last try I drove it, boosted 15 but it would drop slowly to 11-10 (obvious leak) but I fixed it... I dont have the mbc installed anymore...
I think this car was tune and previous owner either had a MBC before and installed the bcs back or the BCS is just damaged .. regardless Im gonna borrow my friends BCS ... !Cry!
sorry newbie here
thanks advance
post #21 of 36 Old 04-26-2013, 05:36 PM Thread Starter
oh yeah I will be getting the pill and lines as well
post #22 of 36 Old 04-26-2013, 08:34 PM
I'd send you one if I had an extra. Good luck.
post #23 of 36 Old 04-27-2013, 08:43 AM Thread Starter
thanks
i'll test it and post results....
post #24 of 36 Old 05-09-2013, 08:33 PM Thread Starter
So i decided to drive my car after a strong rain... car stalled a little bit warmedup and i drove, it was building boost.. i drove on 3rd gear and it was 19 psi and holding .. it will drop to 16... got a CeL ... strange ... pop the hood and notice the vacuum line from the T the goes to the bcd was cut-crack in half... replaced it and and again stock on wastegate psi... i think the bcs is damage... ill be going to autozone to get the codes
post #25 of 36 Old 05-10-2013, 08:32 PM
Brockton's Avatar
Maybe be different for older models, but to get the little hose from the turbo to T fitting, T fitting, hose from T fitting to WGA, and the two pills in those lines, it was $44 plus tax from subaru.
Also I bought this car with a stage 2 tune on it, and it only got 10-11 PSI, found the hose from the turbo to the T fitting was split, got a quick fix hose from autozone, it was slightly too big and that little gap next to the pill kept me at 12-13 PSI, once the replacement hoses/pills came it I started getting full boost.
Brockton is offline
post #26 of 36 Old 05-11-2013, 08:17 AM Thread Starter
you mentioned "two pills" ? I only have 1 pill -restrictor pill if thats what you're referring to ... from turbo inlet to T
post #27 of 36 Old 05-11-2013, 03:13 PM
Earlier models only have 1 pill...., but since you didn't pick me I am not going to tell you what I was going to say before....
post #28 of 36 Old 05-11-2013, 03:36 PM
Hahahaha,
Pick the old man for god sakes, he knows his shit very well.
post #29 of 36 Old 05-11-2013, 05:55 PM
Yeah... pick Keith... he'll tell you it's the manual crank in the front. FOL!!
post #30 of 36 Old 05-11-2013, 08:02 PM
No I refuse to tell you what's wrong with it...I am grumpy like that....I would be willing to bet that you guys can figure it out pretty quickly by looking at the first post....*hint hint* mod list...
