-   -   03 wrx bug eye - boost leak ? (http://www.wrxtuners.com/forums/f52/03-wrx-bug-eye-boost-leak-34153/)
03bugeyeDude 04-15-2013 11:40 PM
Hi everyone.. newbie here, first I'll list the car's mods
FMIC
3" Catback exhasut
Uppie pipe
AEM CAI
I know this been questioned/answered lots of times but I think every case it's different.
I purchased the car a few months ago during winter. I've read 00-03 bug eyes stock boost is around 14 psi but Im only boosting 8-9 psi in every gear but I've noticed (i tried twice) that on 3rd gear at high rpm it will go past 9 and it will reach 14 psi, the 2nd time I tried I got a check engine light got scared reset the ecu and went away. I know i def need a tune since the car came with all these aftermarket parts I only drive the car once a week since I walk to my job... you guys think I have a boost leak, vacuum leak. I even heard about a restrictor pill inside the vacuum lines ...could that be the problem?... !Cry!!Cry!
is there any vacuum line diagram I can download so i check the vacuum lines are installed the right way?
thanks in advance
Jay
pzr2874 04-16-2013 06:43 AM
So you still have the stock downpipe?
Do you have a way to check for boost leaks? ie... boost leak tester, compressor and soapy water in a spray bottle?
Any local meets around your area? This might be your best bet if you can't find any boost leaks
03bugeyeDude 04-16-2013 11:17 AM
no aftermarket as well pzr2874
pzr2874 04-16-2013 12:18 PM
Do a BLT... easiest to try first.
03bugeyeDude 04-16-2013 03:09 PM
hitting 14psi only at high rpm on 3rd gear... isnt that a sign of boostcreep??
brfatal 04-16-2013 09:11 PM
What gears are you only getting 8 psi in? First and second?
Not sure why someone put a FMIC on there. That's actually hurting your car.
pzr2874 04-17-2013 06:31 AM
[quote=03bugeyeDude;295842]hitting 14psi only at high rpm on 3rd gear... isnt that a sign of boostcreep??[/quote]
You have an aftermarket DP, correct? Unless it's "tuned" for 14psi
03bugeyeDude 04-17-2013 01:59 PM
[quote=brfatal;295978]What gears are you only getting 8 psi in? First and second?
Not sure why someone put a FMIC on there. That's actually hurting your car.[/quote]
Im getting low boost in all gears, the only way to get 13-14 psi is when Im on 3rd gear at high rpm and I floor it brfatal...
I dont think the car has to be tune for 14psi since I've read the 02-03 wrxs stock boost is 13-14 psi.... yeah the car came with a FMIC "3 dowwpipe /exhaust catless ....
I even had to fix the vacuum lines once I got the car because the lines were all installed the wrong way.. I wasnt getting any vacuum air flow... Someone even told me the wastegate might be messed up....
pzr2874 04-17-2013 02:16 PM
Do a 3rd gear datalog (if you can)
After a BLT
03bugeyeDude 04-18-2013 04:32 PM
[quote=pzr2874;296386]Do a 3rd gear datalog (if you can)
After a BLT[/quote]
will do this over the weekend thanx
03bugeyeDude 04-20-2013 11:24 PM
did a boostleak test and found no leaks... i do have the restrictor pill in there... lall vacuum lines are well installed ... i doubt the turbo is bad or who knows maybe its the wastegate .... i was thinking that maybe its the bcs that is bad and just replace it... a friend suggested to install a hallman mbc and just tune the car...
pzr2874 04-21-2013 12:20 AM
could always trade out the stock solenoid to see if it still does it.
03bugeyeDude 04-22-2013 08:14 PM
[quote=pzr2874;297761]could always trade out the stock solenoid to see if it still does it.[/quote]
is there a aftermarket BCS I can buy to replace the stock one??
pzr2874 04-23-2013 06:42 AM
None that I know of. 3 ports CAN be run in interupt mode. But you will be on your own on that piece.
03bugeyeDude 04-23-2013 01:14 PM
[quote=pzr2874;298442]None that I know of. 3 ports CAN be run in interupt mode. But you will be on your own on that piece.[/quote]
hey I know I mentioned that I have the restrictor pill in there, I do, but i replaced the T and the vacuum lines; I remember taking the restrictor pill out and put inside another new vacuum line i bought, I wonder if I put it the wrong way or if the vacuum lines have a specific size... do you happen to know the diameter?
this weekend I'm gonna take the whole bumper out and just replace all the couplers and double check the IC pipes... some of those lines have gotten really as hard as a rock (thats what she said) the ones going to the BCS.
