Will the Accessport clear the check engine light once I change to the Stage 2 map? - Subaru WRX Forum
 5Likes
  • 1 Post By Epictofer
  • 1 Post By arcticscythe
  • 1 Post By brfatal
  • 1 Post By thekamikaze kid
  • 1 Post By Subarufan123
post #1 of 11 Old 07-08-2014, 10:58 AM Thread Starter
Subarufan123 is an unknown
Installing my catless downpipe today. It finally arrived, My 03 WRX will be completely catless with no muffler. Will the Accessport clear the check engine light once I change to the stage 2 91 octane tune?
Subarufan123 is offline
post #2 of 11 Old 07-08-2014, 11:09 AM
Epictofer's Avatar
Epictofer is known to be trustworthy and helpful Epictofer is known to be trustworthy and helpful Epictofer is known to be trustworthy and helpful
It can, but you have to tell it what codes to not illuminate the light for.
Subarufan123 likes this.
Epictofer is offline
post #3 of 11 Old 07-08-2014, 11:39 AM Thread Starter
How do I tell it what to not illuminate?
post #4 of 11 Old 07-08-2014, 01:08 PM
arcticscythe's Avatar
On your AP there is a clear codes section, I think its 2 from the top on the root menu. Use the "EXIT" button till you cant go back any further then there is a "check engine" icon. thats where you can clear codes and prevent the system from lighting indicators for thrown codes. That said that wont make the codes go away, your car just wont bother you with the lights.
If it comes time to smog you will still need to handle those codes before passing smog.
- Jason
arcticscythe is offline
post #5 of 11 Old 07-08-2014, 01:11 PM
Flashing the ECU resets it. Assuming it's a cat ineff error, yes it will clear it.
FWIW, don't use Cobb's free maps. They aren't particularly good. Get a custom tune ASAP.
post #6 of 11 Old 07-08-2014, 01:32 PM Thread Starter
I figured I could do that. Wasn't to sure if it would pop up again after resetting the ECU?
Will I be okay to use the stage 2 map till I go and get a ProTune? My buddy has been running a fully catless exhaust on his 04 while running the stage 2 map for over a year now with no problems.
post #7 of 11 Old 07-08-2014, 01:41 PM
the earlier models are way more forgiving than the new ones. your 03 should be fine until you take it to your tuner but don't go tracking it hard until its tuned proper : )
- Jason
post #8 of 11 Old 07-08-2014, 02:06 PM Thread Starter
Sweet, thank you for the quick feedback. I'm pretty excited for the install and how she's going to sound. I'll post up a video after everything is done later today. Thanks again for the help.
post #9 of 11 Old 07-09-2014, 06:28 PM
Brockton's Avatar
Not sure about on the AP, but with open source you can go into the rom and turn off the codes, when you hook up a obdII code reader they won't appear. So you can pass smog and not be bothered with it.
Brockton is offline
post #10 of 11 Old 07-09-2014, 08:52 PM
thekamikaze kid's Avatar
howd it go Subarufan123?
thekamikaze kid is offline
post #11 of 11 Old 07-09-2014, 11:43 PM Thread Starter
It went great. Installed the downpipe and then flashed the stage 2 tune. No check engine light on the start up and hasn't appeared yet.
Here's what she sounds like now
https://www.youtube.com/watch?v=TixeIYHD34Q
thekamikaze kid likes this.
