-   -   will 04/05 STI springs fit an 02 wrx Plus Bushing Question... (http://www.wrxtuners.com/forums/f51/will-04-05-sti-springs-fit-02-wrx-plus-bushing-question-44330/)
Cosmo_kraemer 01-26-2014 07:36 PM
Ok so i have two chances to grabs some springs off an 04/05 STI and maybe for pretty cheap since i need to replace my rears, are sagging a bit. would the springs work or will i have to get anything to make them work.I have looked around and everything i have read is confusing me.
mosc 01-27-2014 08:22 AM
04 STi uses the same strut layout as the WRX. I wouldn't take just the springs, the stock WRX struts are junk. The springs are compatible though, performance aside. The 05 STi has different struts but I am unsure about the springs (they might very well be the same).
Cosmo_kraemer 01-27-2014 10:29 AM
Damn he has the stock struts and springs. But the rear knock. And it's off an 05 so does anyone know what else I would need to make the 05 struts fit????? I'm tired of the rough bouncing. And the squared look in the rear
brfatal 01-27-2014 11:00 AM
How many miles are on these struts?
The 2002-2003 and 2004-2007 WRX front top hats are not compatible with the other model's springs. You'd need later model top hats for it to work.
Cosmo_kraemer 01-27-2014 11:27 AM
Miles are unknown. So if I just got the springs I would have to get the top hats to. Is there anything else tho.and over time I want to get some nice struts and springs. As of now I just want to have the ride smooth and look good not squaring the wrong way.
mosc 01-27-2014 12:26 PM
using 05-07 STi struts would be prohibitively expensive. You need the hubs, which means brakes, which is just a nightmare. Not an option.
04 STi struts are not a big deal to put on a WRX.
Cosmo_kraemer 01-27-2014 12:40 PM
well the struts since its an 05 are out of the question then thanks.now to wonder if the springs are still good and see if i can grab the top hats. do i need the top hats just for the rear or the front also?
BLAZE2099 01-27-2014 05:26 PM
[quote=brfatal;428442]How many miles are on these struts?
The 2002-2003 and 2004-2007 WRX front top hats are not compatible with the other model's springs. You'd need later model top hats for it to work.[/quote]
I have done this on my 02.
It's the rear tophats that are needed for springs.
I kept my fronts.
I pretty much just gave my STi tophats away to another well respected member;)
Cosmo_kraemer 01-27-2014 06:36 PM
thanks randy Text inbound........
so i shot him an offer on the springs, and Hats.
brfatal 01-27-2014 08:28 PM
Sorry, I meant rear not front top hats. Good save.
Cosmo_kraemer 01-27-2014 09:03 PM
Well i got damn lucky i got the top hats and the four springs for 40 bucks and the springs only have 43k on them. now to wait for them and then figure out how to put them on.
BLAZE2099 01-28-2014 05:35 AM
[quote=brfatal;428946]Sorry, I meant rear not front top hats. Good save.[/quote]
I gotcha homie;)
Good deal Chris!
If you need help with the install, just let me know.
Your gonna want spring compressors. You can get ok ones on eBay for around thirty bucks I think.
arewmors 01-28-2014 05:55 AM
Also to add to Randys post, you can rent spring compressors from your local auto parts store. You pay a fee for the rental and get the money back when you return the rental. I've rented the kit, for past projects. Works well. I wouldn't buy one unless you're going to use it a lot more than this one time.
Surprised you didn't think of that Randy, being the penny pincher you are. Fol, ;)
BLAZE2099 01-28-2014 06:35 AM
I do springs often.
I've used mine seven times in five years. And for the low cost... Ehh
But if you're a one and done.. Rental is for you
Cosmo_kraemer 01-28-2014 09:04 AM
Thanks everyone. I have talked to someone I know in SD and he has the tool and done his before. Well the springs atleast. But I will hit you up Randy since you have done the swap before on ## Bugeye.
