-   -   What would changing the springs do for a vehicle. (http://www.wrxtuners.com/forums/f51/what-would-changing-springs-do-vehicle-44346/)
Omar Bee 01-26-2014 08:00 PM
Sorry im new to all this and just learning, so if im to change my springs what advantage and disadvantages come with the vehicle?:(
BLAZE2099 01-26-2014 10:07 PM
Really depends on the spring.
Lower, raise or just go stiffer or softer.
TuckersWRX 01-26-2014 10:10 PM
Springs can change multiple things. It all depends on what ones you get and what purpose they have.
As Blaze said they can basically change the height of your subie, and change how it will ride.
YouFoundDonon 01-26-2014 11:47 PM
[quote=Omar Bee;428074]Sorry im new to all this and just learning, so if im to change my springs what advantage and disadvantages come with the vehicle?:([/quote]
I would love to lower my car, but unfortunetaly living in New England I'll become a plow during the winter, and having to constantly change springs to the weather conditions would be annoying. That and I wouldn't get up my steep driveway "(
brfatal 01-27-2014 10:58 AM
Depends on the spring. Some are handling oriented and some are purely aesthetic. Depending on which you will get less body roll and a more firmly planted ride. Get the wrong spring and you can reduce handling and lower it too far and/or reduce the lifespan of your struts.
arcticscythe 01-27-2014 12:13 PM
Springs are there to hold your vehicle off the ground. they work in concert with your struts to provide an upward force opposing gravity. Springs are held in place by your struts and the struts act to slow down the expansion of energy that is displaced by your car hitting a bump.
Harder springs will make your ride stiffer, softer springs will make your ride more squishey. you can also buy "lowering springs" that are physically shorter than stock, or "raising springs" that are taller than stock.
if you want to learn more about springs and struts I recommend "how stuff works" its hosted by the discovery network and its full of great resources if your looking to learn more about cars in general
[url=http://auto.howstuffworks.com/car-suspension.htm]HowStuffWorks "How Car Suspensions Work"[/url]
mosc 01-27-2014 12:36 PM
Good links guys!
I would add that springs are more than just a length and a springrate. Good springs are often graduated to respond to small bumps with firm response but be more forgiving on larger bumps to avoid jarring your teeth out. Their function is often highly dependent on other suspension components so be careful changing just one part without regard for the others. Good suspension systems take a large number of factors into account that deal with the overall geometry of your car, it's weight, and it's dynamic response. What works on one car may not be applicable to another.
PROImportTuners 01-27-2014 03:13 PM
Good Points everyone!
Like most people mentioned there are a number of benefits that springs can provide and there are some that do certain tasks better than others.
Feel free to give us a call or send an email if you need help choosing which springs will work well for your intended use!
Toll free: 1-888-9-PRO-TUNERS
Email: [email]customercare@proimporttuners.com[/email]
sleepr 02-05-2014 02:34 AM
IMHO, any "advantage" (handling, lowering, etc.) will be significantly increased if you replace both the springs and the struts (the strut assembly) at the same time. However, replacing the springs only is certainly something that many people have done.
03bugeye scoob 05-07-2014 10:14 PM
Lowering springs will reduce the life of your shocks, it's a bit more money but I'd just look into adjustable coil overs if your intent with new springs is to lower your car...this way to u can always dial in on how u want your car to feel and react, u get what u pay for ...ya u can get lowering springs fairly cheap for couple hundred bucks but in long run will cost u money in struts so spend the extra buck and and go with adjustable coil overs
brfatal 05-07-2014 11:01 PM
[quote=03bugeye scoob;452585]Lowering springs will reduce the life of your shocks, it's a bit more money but I'd just look into adjustable coil overs if your intent with new springs is to lower your car...this way to u can always dial in on how u want your car to feel and react, u get what u pay for ...ya u can get lowering springs fairly cheap for couple hundred bucks but in long run will cost u money in struts so spend the extra buck and and go with adjustable coil overs[/quote]
No.
Coilovers have shorter lifespans than struts with good lowering springs. Generally speaking they need to be uninstalled and sent off for service every 30-40k miles if not sooner. Not to mention they are less reliable and much more maintenance intensive than springs and struts. Also, coilovers worth more than their weight in dirt run +$1,500 on GDs on +$2,000 on later models. Overall for a DD/street car they are not the best decision. You're spending +$1,500 on adjustments and capabilities you can't full utilize outside of competitive track settings and have to follow through with the extra care that they need without getting the real benefits they offer.
Bluntly put, not a single person on this forum can out drive a good strut and spring combo on public roads. Unless you race competitively, coilovers would be a redundant purchase IMO.
arcticscythe 05-07-2014 11:19 PM
[quote=brfatal;452625]No.
Bluntly put, not a single person on this forum can out drive a good strut and spring combo on public roads. Unless you race competitively, coilovers would be a redundant purchase IMO.[/quote]
Amen Brother:) Coilovers are very pretty but until you have a team of experts setting your car up for a particular track they are an unfortunate waste of adjust-ability.
PROImportTuners 05-08-2014 11:47 AM
Keep in mind probably the biggest advantage of a good coilover system (over a spring/shock combo) is that the manufacturer matches the shock valving with the spring rate, for optimal handling and ride characteristics. I understand on some lower end coilovers this is not done, but on the good ones it definitely is.
The other nice thing is that sometimes you don't know exactly how much you want your car lowered, or you change your mind later. With a spring and shock combo, you are stuck at one ride height forever.
