Old 07-13-2008, 02:50 PM   #16 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi isn't as helpful as most
The VF39 is a decent turbo for the 2.0. I would suggest, as everyone else has, the STi pinks and an STi TMIC. Make sure you get a new y-pipe as the stock WRX one won't fit.
Also, make sure you get a tune as soon as possible. You'll need the injector scaling changed, as well as boost, timing, and fuel maps adjusted. If you have a tactrix cable and ROMraider software, it isn't that difficult. Not sure who on this site is the "go to" guy for OpenECU but if you stop by STLSubaru, talk to Testes1010. He's in Indiana and tuned mine for the VF34, STi pinks, Walbro 255, etc. I'm sure he can help you out.
Old 07-14-2008, 11:29 AM   #17 (permalink)
ImNASTI's Avatar
Club Region: Southeast
Reputation: ImNASTI is an unknown
Send a message via Skype™ to ImNASTI
Will a Cobb AP suffice? thats more likely the route i'm going to go.
And for an intercooler, will one from ebay do, like a godspeed? I'm thinking they are cheaper for a reason
Old 07-14-2008, 02:16 PM   #18 (permalink)
Longshot's Avatar
Car: 05 WRX
The AP has a map designed for the vf39 so you could flash that once installed. I'd still recommend a protune though. For a larger tmic, go with a used STi tmic IMO they will suit your needs just fine. If you're going to go the ebay route look at the X02 TMIC or the SSAC, both are larger than the STi but you may have to fiddle with fitment.
DTRacing Tuned
Old 07-14-2008, 05:03 PM   #19 (permalink)
Yes, an E-Bay TMIC will work as long as you get the y-pipe to fit. I'm using one for my VF34 setup.
As for using the CobbAP. . . If you want to spend ALOT more, have on the fly map switching, and the whole customer service aspect. Sure. Personally, I'm using ROMraider. It's free, and very similar to the Cobb Street Tuner. The only disadvantage I've found is there is no on the fly switching. But, honestly, I don't need that ability since I'll drive to a track, reflash, race, reflash, drive home. Reflashing only takes about 2 minutes.
Old 07-14-2008, 06:52 PM   #20 (permalink)
bocaks's Avatar
Club Region: Western Canada
Reputation: bocaks is an unknown
I hate cobb more than most and I'm still going to warn you about the possible problems associated with alternate(custom maps). I use openecu and rom raider on my 02 but after a year I am still having trouble finding a tuner and a dyno. this is not a problem everywhere but you need to have a solid plan in place for tuner and place to tune b4 you make that choice. the only advantage cobb AP has is that they have factory style maps(safety margins are still intact and map will work ok anywhere.ie elevation and climate.)already worked out for different setups. if you chose to use one of there maps aim to match your car to their modlist for given map. if you want to make your car any hairyer than their options provide you must tune yourself or with a tuner. so if your cool with map
- VF39 turbo, STi TMIC, STi "Pink" 565cc injectors & Turboback exhaust using 93 octane. 349HP (+54%) / 299lb-ft (+38%)----
than by all means go that route. but if you want to pass the 310+AWHP range you will need a more agressive tune.
its all coming together, after a year.
02 WRX
Old 07-15-2008, 11:21 AM   #21 (permalink)
ImNASTI's Avatar
Thanks for all the input guys. I will probably go the AP route, this is going to be my daily driver, so i dont need an overly agtressive tune, i have no desire to destroy my bottom end or anything else.
I'm going to be posting some new pics in the near future, i've ordered things to make the exterior look good as well.
Old 07-16-2008, 01:06 AM   #22 (permalink)
Reputation: newtothegame is a helpful contributing member
Keep us posted as to what you go with and how things turn out. Best of luck to you.
"Im back and its great."
Old 07-19-2008, 09:23 AM   #23 (permalink)
ImNASTI's Avatar
update
so i have all the parts orderd i need for the VF39 swap, except 1, the $*#&$(# stock BOV. I found one but the guy backed out at the last minute. so, if i cant find one, what is the best alternative???
so far i have my VF39, STI pinks, STI TMIC, COBB AP, walboro Fuel pump, world rally decals for the exterior (those add at least 40 hp to the wheels,....to the wheels! )so all i need is the BOV ,....
one of my mustang friends said i might need an MAF with the injectors, is that true? just want to make sure i have everything. It will probably be installed within the next 2 weeks
Old 07-19-2008, 09:40 AM   #24 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is an unknown
Why would you need a different MAF..... you are going to flash the COBB OTS ? Right ? Cobb's OTS does not call for anything more than what you have. Actually it doesn't call for a bigger pump I don't think.
2007 WRX
Old 07-19-2008, 03:11 PM   #25 (permalink)
The MAF can be scaled to huge power levels. Your mustang friend apparently doesn't know much about 4-cylinders. The stock MAF is a MUST for most tuning, including the Cobb AP. Even when you're making 500whp
Engineers can't spell, sorry!
Online
Old 07-19-2008, 04:24 PM   #26 (permalink)
Why do you need a stock BPV? I'm not sure what you would really need a stock one for.
Old 07-19-2008, 05:12 PM   #27 (permalink)
Probably because his tuner told him it was causing a problem. As I explained, the map he started with was intended to have the stock BPV and the tuner was probably unable to work around what was there. Hence, you're current tune is essentially better off with the stock BPV than what you got even though it was tuned with that mod on it already.
Online
Old 07-19-2008, 06:56 PM   #28 (permalink)
Ah, good point. That would be the best route then especially since any BOV will cause a rich condition between shifts.
Old 07-20-2008, 09:05 AM   #29 (permalink)
Reputation: dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to
Nope.Their MAF sensor is designed different than ours.It is incased in it's own housing that cannot be altered or removed.Ours can be removed from one size housing and placed in another but needs to be retuned/rescaled.
Aarg matey!
ECU Pirated by RomRaider
Old 07-22-2008, 02:46 PM   #30 (permalink)
ImNASTI's Avatar
Bump so everyone can see the new decals and tint. Posted 2 pics in the gallery.
