-   -   V3 Accessport won't connect to Accessport Manager? (http://www.wrxtuners.com/forums/f51/v3-accessport-wont-connect-accessport-manager-45761/)
Subarufan123 03-13-2014 02:28 AM
I've tried using different USB's but the Accessport Manager still won't pick up my Accessport. Anyone else had these issues?
Bubba James 03-13-2014 08:59 AM
Yes and it was the cord for me. I used a different one (a PlayStation cord I think) and it worked fine after that. The cord they sent was screwy.
arewmors 03-13-2014 10:03 AM
You could contact Cobb and see if they will send you a new cord as well. They should be contacted either way to be made aware of the issue in case it becomes a common problem then they can look into fixing it.
Subarufan123 03-13-2014 12:18 PM
[quote=Bubba James;440553]Yes and it was the cord for me. I used a different one (a PlayStation cord I think) and it worked fine after that. The cord they sent was screwy.
[color=gray]Sent from [url=http://www.autoguide.com/mobile]AutoGuide.com Free App[/url][/color][/quote]
I tried most of the USB's I have and it won't pick up the Accessport still. I'll try and get Cobb to send me a new one.
[quote=arewmors;440569]You could contact Cobb and see if they will send you a new cord as well. They should be contacted either way to be made aware of the issue in case it becomes a common problem then they can look into fixing it.[/quote]
I will contact them today to let them know the issues I'm having and see what they say. I will also ask for another cord.
Bubba James 03-13-2014 01:40 PM
"tried most of the USB's"? You mean you tried diff ports? Do you have a droid charger (micro USB)? Try that cord. Go to device manager on you computer (if you have PC) and see if your USB port has a "?" Mark next to it... Rule out the port that way.
thekamikaze kid 03-13-2014 06:14 PM
yah bubba is right. its prob not the cord but a "driver software" problem. go into device manager and "scan for hardware changes" with the cord plugged in. you should see a balloon in the lower right that says whether or not the driver loaded or not. if it says cannot load driver i would try reloading the program. maybe the software did not load correctly from the start. what operating system are you using?
Subarufan123 03-13-2014 08:18 PM
[quote=Bubba James;440585]"tried most of the USB's"? You mean you tried diff ports? Do you have a droid charger (micro USB)? Try that cord. Go to device manager on you computer (if you have PC) and see if your USB port has a "?" Mark next to it... Rule out the port that way.
Perfect, I'll give that a shot when I get off work tonight. It's a Nokia charger.
[quote=thekamikaze kid;440657]yah bubba is right. its prob not the cord but a "driver software" problem. go into device manager and "scan for hardware changes" with the cord plugged in. you should see a balloon in the lower right that says whether or not the driver loaded or not. if it says cannot load driver i would try reloading the program. maybe the software did not load correctly from the start. what operating system are you using?[/quote]
I am running the program on Windows XP. I uninstalled the Manager then installed It again. I'll give that a shot and see what happens.
itiswhatitisnt 03-14-2014 06:31 PM
I just purchased a COBB Accessport and my USB Cord/wire worked fine. Contact COBB.
Good Luck
Subarufan123 03-17-2014 01:22 AM
[quote=itiswhatitisnt;440953]I just purchased a COBB Accessport and my USB Cord/wire worked fine. Contact COBB.
Good Luck[/quote]
Turns out it's my computer. I downloaded the Accessport manager on a different Computer(windows vista) and it connected no problem.
itiswhatitisnt 03-18-2014 02:32 PM
[quote=Subarufan123;441425]Turns out it's my computer. I downloaded the Accessport manager on a different Computer(windows vista) and it connected no problem.[/quote]
Glad it was a simple fix for you.
Now back to logging! lol :)
