tuning a must if do downpipe and cat back? - Subaru WRX Forum
post #1 of 24 Old 04-07-2012, 08:23 PM Thread Starter
tsmithr34 is an unknown
I recently got a 2008 wrx hatch, a shop said I would HAVE to tune the car if I were to put on a downpipe and cat back exhaust. Is it really necessary? I'm just looking to do a couple things to it, not dumping alot into it. Thank you for any replies.
tsmithr34 is offline
post #2 of 24 Old 04-07-2012, 08:42 PM
Not the cat back, but the down pipe... Yes
post #3 of 24 Old 04-07-2012, 08:43 PM
Yes, just for the DP.
post #4 of 24 Old 04-07-2012, 08:45 PM Thread Starter
because of the cat after the turbo right? thank you
post #5 of 24 Old 04-07-2012, 08:55 PM Thread Starter
wait, would that matter bacause doesn't the turbo make the back pressure that the engine needs?
post #6 of 24 Old 04-08-2012, 08:55 AM
Search around for pics of the stock exhaust versus any other aftermarket one. The aftermarket ones allow for more are to flow thru them effectively changeing everything in the process. Listen to the people that been doing this awhile, or you can take the chance of ruining your brand new toy.
post #7 of 24 Old 04-08-2012, 10:26 AM
bad grocerygetter's Avatar
It's because the stock downpipes have a plate over half of the opening. Aftermarket ones do not. Doesn't have anything to do with the cats.
Kevin.
bad grocerygetter is offline
post #8 of 24 Old 04-08-2012, 10:44 AM
That's not why you need the tune.
This has absolutely nothing to do with it either. Some aftermarket ones are flat plate as well.
HKS
Greddy
There is a fueling delay between the OL and CL fuel transition. When you remove the cats the turbo spools up faster and the switch happens sooner. The delay needs to be removed so as to prevent a split second where you would otherwise run very lean.
post #9 of 24 Old 04-08-2012, 01:30 PM
mazzanic's Avatar
mazzanic is an unknown
Im in the same rut. I have a DP sitting but no tuner. So just make sure u tune or youll blow her up
mazzanic is offline
post #10 of 24 Old 04-08-2012, 07:05 PM Thread Starter
Thank you very much for clearing that up everyone
post #11 of 24 Old 04-09-2012, 12:20 AM
Klone's Avatar
Klone is an unknown
or u can get an e-tune. GL
Klone is offline
post #12 of 24 Old 04-09-2012, 07:48 AM
Quote: This has absolutely nothing to do with it either. Some aftermarket ones are flat plate as well.
Wow I had no idea! Thanks for sharing that. I knew about the ol-cl delay but I thought it was more with tuning for an intake. But I see how I would be affected with the exhaust stuff.
Kevin.
post #13 of 24 Old 04-09-2012, 08:57 AM
Bugeyes don't have the delay.
post #14 of 24 Old 04-09-2012, 12:17 PM
wrxdan's Avatar
wrxdan is more helpful than not
i just got a tactrix cable and downloaded ecu flash, then went to xpt tunning and got a stage 2 ots map, works great. probably the cheapest way to get some more power out of it.
u'll be surprised in the difference it makes over stock
wrxdan is offline
post #15 of 24 Old 04-12-2012, 10:15 AM
Awrecks's Avatar
Awrecks is an unknown
blew up my 2004 this way ran downpipe with no tune for a year and a half and she blew. do yourself a favor.. get a tune. NOW!
Awrecks is offline
