???synthetic oil??? - merged - Subaru WRX Forum
 2Likes
post #1 of 16 Old 12-04-2006, 01:01 PM Thread Starter
06TR06's Avatar
06TR06 is an unknown
Question ???synthetic oil??? - merged
Is synthetic oil any good for my 06 TR?
:)!!!warning! - girl behind the wheel!!!:)
06TR06 is offline
post #2 of 16 Old 12-04-2006, 01:28 PM
JOHNYCAMP's Avatar
JOHNYCAMP is an unknown
mobil 1 , redline , or royal purple works nicely.
JOHNYCAMP is offline
post #3 of 16 Old 12-04-2006, 01:45 PM Thread Starter
06TR06's Avatar
Question
some people are saying that synthetic can harm my engine...
06TR06 is offline
post #4 of 16 Old 12-04-2006, 02:59 PM
As discussed many times before, synthetic oils are far superior to 'dyno' oils. They are able to withstand higher temperatures and lubercate better at those temperatures. They also don't cake up like dyno oils can at extreme temperatures. You can only benifit from switching.
However, the problem with synthetic oil is that they lubercate too well. In order to properly break in a new engine or even a new turbo for that matter, you have to run it with old fashion dyno oil first. After that, it is usually safe to make the switch. Don't be switching back and forth either. Stick with one.
And regardless what people say, synthetic does not allow you to extend your change intervals. It all depends on the way you drive, where you drive, and the how well your filter work is... filtering. The only TRUE way to tell if the oil needed to be changed is getting it chemically tested at a lab. 3750miles is Subaru's recommend change interval.
the RIOT act likes this.
post #5 of 16 Old 12-04-2006, 03:40 PM
bigbadbuddha's Avatar
Images: 15
Vew you are my hero...
Synthetic all the way.... I run Amsoil and love it.
I change my oil every 3000 miles at most....
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #6 of 16 Old 12-04-2006, 03:52 PM
Ditto. Oil is cheap. Repairs aren't.
post #7 of 16 Old 12-04-2006, 03:53 PM
WRX_JUNKI's Avatar
WRX_JUNKI is an unknown
Send a message via AIM to WRX_JUNKI
I just stick to what they recommend.
Keith
WRX_JUNKI is offline
post #8 of 16 Old 12-04-2006, 08:36 PM
Black05WRX's Avatar
Black05WRX is an unknown
synthetic oil also wont coke the turbo up if you dont let it idle like dyno oil will.
Black05WRX is offline
post #9 of 16 Old 12-04-2006, 09:39 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Don't ever listen to those people again. Synthetic is the best for our cars. Just make sure if you use it that you never switch back and forth between regular and synthetic
Ian is offline
post #10 of 16 Old 12-06-2006, 06:52 AM
Flat 4 is an unknown
2005 STi- Synthetic Oil?
I was debating on upgrading to using synthetic oil. My car has 26,600 miles on it. Would it be beneficial to upgrade, and is it even recommended by Subaru to run synthetic in the STi's motor?
I've never used synthetics in any of my previous vehicles, and have never run into problems, so I'm a bit skeptical. Also, how long would I be able to go between oil changes?
Flat 4 is offline
post #11 of 16 Old 12-06-2006, 08:29 AM
Yes, and the interval is the same as before.
post #12 of 16 Old 12-06-2006, 09:19 AM
Blzzrd is an unknown
Send a message via AIM to Blzzrd Send a message via MSN to Blzzrd
In addition to what Vew said, please note that when you start using synthetic you cannot go back to regular without getting flushed.
Blzzrd is offline
post #13 of 16 Old 12-06-2006, 12:49 PM
Strider327's Avatar
Strider327 is an unknown
Two Words: HELL YEAH!!!
Strider327 is offline
post #14 of 16 Old 12-06-2006, 03:09 PM
joker97's Avatar
joker97 is an unknown
synthetic! i dont think we can find non synthetic oils in this country!
joker97 is offline
post #15 of 16 Old 12-06-2006, 04:32 PM
Ian
Ian's Avatar
Really?
Ian is offline
