Old 02-18-2004, 08:34 AM   #1 (permalink)
WRXtreme's Avatar
Reputation: WRXtreme is more helpful than not
susp. or ecu
ok, i got some decent overtime this pay check, got a tax return and an selling some subs on e-bay. So, I should have about 1g to drop or so on my car, more if needed. I was debating on suspension or ecu mods. If I go with susp. I was planning on perrin/eibach springs, koni shocks and a ###### a eibach camber kit. if i go with the ecu, i'd ###### go with the UTEC, only i don't know hardly anything about tuning a car, i see that you can download maps though. i only have a custom cat-back exhaust so far as a mod. What are your suggestions?? If you think suspension i want the to get the best.
Thanks in advance,
-Adam
Old 02-18-2004, 08:37 AM   #2 (permalink)
Cosmo's Avatar
Depends on what you want to do with the car. If you want better handling, go with the suspension. If you want more power, go with the UTEC. Don't worry about not knowing how to tune it. There are many people on this board (myself included) who will be glad to help.
Old 02-18-2004, 09:18 AM   #3 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
Cosmo is right its up to you and what you wanna do, but if I were you spend it on a UTEC, then later buy some lowering springs, sway bars and nice wheels and that should be a nice change. And if you need more suspension but a front strut bar. But personally I would go with UTEC and learn to tune it.
Old 02-18-2004, 02:34 PM   #4 (permalink)
WRXtreme's Avatar
well the thing is i don't really plan on doing any other performance mods till i have it paid off(less than 2years). I wanted a new car for a reliable car so i don't always have to put money into it just to keep it running. i just figured suspension work b/c that will not void my drivetrain warranty. from what i understand the utec just plugs into the ecu, it maybe a little more difficult, but thats generally it. I figure i am going to need the utec someday anyway as a basis from my future mods i have planned.
If you had the choice what what would you get?? UTEC or Suspensions Mods???
Old 02-18-2004, 08:41 PM   #5 (permalink)
Reputation: stiffler is an unknown
Honestly I would take the UTEC first only because it is very easy to install and uninstall if needed to get warranty work done. And this will give you time to learn to tune it when you decide to start modding more.
Old 02-19-2004, 07:08 AM   #6 (permalink)
WRXtreme's Avatar
so if i do get a u-tech do you suggest a e-bay sale and save $150 or buy it from a shop. I'm don't really like using ebay that much expecially for stuff that expensive.
Old 02-19-2004, 09:17 AM   #7 (permalink)
Car: 04 WRX
Trader Rating: (1)
Buy from Turbo XS. On their website they talk about Ebay scams.
Old 02-19-2004, 02:09 PM   #8 (permalink)
WrexKid03's Avatar
Reputation: WrexKid03 is an unknown
Send a message via AIM to WrexKid03
QUESTION ABOUT THE UTEC
do all their maps make it so you have to run 93 octane because i heard utec has a big problem with engine knock and pinging
Old 02-19-2004, 02:10 PM   #9 (permalink)
WrexKid03's Avatar
also i know for stage 1 they have a map for 91 but what about the other maps like stage 2 through 4
Old 02-19-2004, 05:30 PM   #10 (permalink)
Car: 04 WRX
Trader Rating: (1)
I think they have octane challenged maps and if not, I am sure somebody on here will help you with it or wrxhackers.com might have the octane challenged.
Old 02-19-2004, 09:45 PM   #11 (permalink)
Jmoney007's Avatar
Reputation: Jmoney007 is an unknown
Send a message via AIM to Jmoney007
I would go a complete suspension tip. If u bring that up in your desicion making choices then handling will be an important choice for u.
I would go lowered springs(tein,perrin,h&r,eibach,etc)=250
Front and rear sway bars plus rear end link = 400
koni shocks or kyb agx for like 450
Or engine management. There are more than one type available....
I happen to have a utec.. alot of members here do too.
but there are others.. ANd they all run a bout 1 g.
UTEC
The UTEC is a new concept in WRX engine management delivering the power and control of a stand-alone engine management system with the convenience and tuning ease of a piggyback system. UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over tedious and mundane functions that make the car drivable on a daily basis. Functions like cold start, hot start, intake temperature compensation, AC compensation and closed loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend your tuning time doing what we all like to do – making your WRX faster!
LINK 44-S ENGINE MANAGMENT COMPUTER
The Link 44-S engine management computer is a must have ECU for the WRX owner planning on modifications beyond that of basic bolt-ons. A plug and play solution, the Link 44-S ECU eliminates the pesky factory MAF sensor and uses the MAP sensor for load reference. With 200 point fuel and ignition maps, the Link ECU retains full control over ignition, fueling, TGV’s. The Link ECU also allows the control of boost pressure, cold start, closed loop, knock settings, air conditiong / cold start enrichment, as well as a host of other features. Combined with the PC-Link the Link ECU is fully user programmable.
ECUTEC
The EcuTek software has now allowed us to reprogram the stock ECU for optimal power and driveability. Wheather you have a stock car or a 400 HP monster we can make sure that you are getting the most out of your parts without sacrificing comfort and saftey. This is a powerful combination. Get in on the action.
AccessECU
We are excited to offer the most advanced ECU software upgrades for the Subaru WRX made possible by the revolutionary AccessECU technology. By directly accessing the stock ECU, we can reprogram the engine management functions with improved performance in mind without sacrificing any of the robust safety and driveability features Subaru has incorporated.
Just Ideas
jeremy
Old 02-19-2004, 11:00 PM   #12 (permalink)
Zaphod's Avatar
Car: 04 WRX
Reputation: Zaphod is an unknown
I'd go with the suspension. The UTEC will get you some good power benefits, but if you want reliability and a completely worry-free commute, just keep the engine management stock and get that thing handling better. Then, when you are paid off on the note, just start building the engine the way you want it, and add the appropriate engine management when you get to that point. Just my two cents
From deep within our secret souls
Do demons dwell and take control...
Old 02-20-2004, 12:57 AM   #13 (permalink)
tod
Registered User
Reputation: tod is an unknown
One thing in favor of buying the UTEC is that you have the large amount of cash needed. The suspension stuff you can do bit by bit. Yeah, I know you should do the springs and struts together. But, you can do swaybars, links, camber kits, etc. as need (or your wallet) dictates.
On that note, are camber kits required when lowering a WRX? I know this can vary from car to car - most Hondas need compensation (or is that Honda drivers, hee), while F-Bodies don't. With Mustangs, it varies from car to car!
By the way, before I get nasty responses from the Honda drivers, that was a joke.
Tod
Old 02-20-2004, 12:00 PM   #14 (permalink)
WRXtreme's Avatar
As far as suspension is concerned, I was going to do struts and springs at the same time. I can R&R most things, but i do not have the tools nessacery(sp??) to do it, so i will have to pay for installation. Springs($220), Shocks($550) + alignment is gonna be $1000. I do have the money right now to do out and get the Utec in cash. There is a dyno day around here tommorrow for turboforum.net and i was thinking about going, maybe i'll go get my utec today.....So many decisions. Also with suspension, you have so many choices to make with like 10 kinds of springs, 5 kinds of shocks, with the ecu, in my eyes you have just 1 choice, UTEC.
Old 02-20-2004, 09:10 PM   #15 (permalink)
fc735's Avatar
for what you are looking at, i would go with suspension mods first. get it handling well, and learn how to run it stock first, and go from there.
what year is yours? an 02-03 i assume?
and for the camber kits....i dropped mine and SEVERAL other cars with different brands, and as long as you like an aggressive camber setting, and drive it like it should be, you wont have tire wear due to camber. make sure the toe is set all the way around after the drop, though.
however, if you are lowering it for looks only (which you should be shot for that ) then you will need camber bolts to take care of your neg. camber.
