Alright here we go. Does anyone know about maXpeedingrods Racing Coilovers? I think they are very good quality and I will recommended for you!
Link: Amazon.com: maXpeedingrods For Subaru Impreza WRX STI GDF Adjustable Coilover Suspension Coilovers kit: Automotive
Features:
* Adjustable ride heightb
* Adjustable pre-lod spring tension
* 24 levels of adjustable damper -- This allows you the ability to perfectly dial in your coilovers system. You can enjoy confortable riding experience in all road conditions.
* Pillow ball top mount -- this design helps combat noise while tuning. It also improves the steering feel and response
* Most components are made from 6063 aluminum with T6 for increased hardness -- the advantages include excellent strength, and aluminum helps keep the weight down.
* Hi Tensile performance spring - Under 600,000 times continuously test, the spring distortion is less than 0.04%. Plus, the special surface treatment is to improve the durability and performance.
* All inserts come with fitted rubber boots to protect the damper and keep clean.
* Improve your handling performance without sacrifice comfortable ride.
* A fast and affordable way to easily upgrade your car's appearance.
* Easy installation with right tools.
* Ideal for any track, drift and fast road and can also be used for daily driving.
Features:
