Stage 2 tuning 09 wrx - Subaru WRX Forum
post #1 of 8 Old 05-17-2012, 12:08 AM Thread Starter
tweak is an unknown
I just installed an aem intake and an invidia catless downpipe with a q300cat back on my 09 wrx. I am looking into my options for getting a tune (either pro or cobb ap). Will the ap fix the boost creep completely or would a pro tune be better? My friend has suggested about just getting a bigger wastegate and a tune. I do plan on doing more mods later on. I am just curious what my best options are and what other peoples experiences are with this.
tweak is offline
post #2 of 8 Old 05-17-2012, 12:36 AM Thread Starter
tweak is an unknown
How reliable is the open source stage 2 map from xpt tunning?
tweak is offline
post #3 of 8 Old 05-17-2012, 01:07 AM
undrbst is an unknown
So you're running those mods without an AP or tune?.....WOW! Hope you aren't beating on the car. Might as well go with the tune since you have the mods to support it but you need something ASAP. I'm running stage 1 on the AP with no boost creep. Hope to go stg 2 next month and will continue to use the AP for about 2-3 mos before I get a protune. I highly recommend reading thru the threads before slapping parts on your ride.
Engine + mods - AP/Protune = fail
undrbst is offline
post #4 of 8 Old 05-17-2012, 01:14 AM Thread Starter
tweak is an unknown
since the mod, i have done my research. Definitely a noob mistake. im not drivign the car anymore until a tune is done. Is the ap worth the extra money over tactrix and the cable? is a new waste gate worth it with a protune?
tweak is offline
post #5 of 8 Old 05-17-2012, 01:52 AM
I've read a Protune or tactrix w/ cable are cheaper than the AP. I went with the AP because I knew it was going to be awhile before I upgraded to stage 2. Although I really enjoy having the AP I will eventually get a Protune shortly after I go stg 2. A buddy of mine who has an 11 STI hatch has both. He just uses the AP every now and then to make sure the car is running right. For me the AP was a good investment.
BTW the stock wastegate should be fine unless you're going big. Might want to consider the Grimmspeed EBC though.
undrbst is offline
post #6 of 8 Old 05-20-2012, 10:03 AM
AllExtinct's Avatar
GS EBC needs a pro-tune so unless you def. on planning getting that I wouldn't get the EBC.
AP is good to a certain extent, OS is good from what I heard but you have to know what your doing.
I def. wouldnt drive that car again till you get some kind of EM unless you paln on going back to stock.
I would also remove that Intake and go back to stock, alot of people had problems with intakes unless tuned for it.
If your looking for a long distant tune go with OS if your looking for a quick and limited tune go with AP.
I went with AP since I don't plan on doing any more mods for a while and changing maps are so easy a caveman can do it!
GL Man.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #7 of 8 Old 05-20-2012, 04:42 PM
joshbm1 is an unknown
That is a dangerous situation without a stage 2 map or protune. I would suggest a pro tune. ASAP
joshbm1 is offline
post #8 of 8 Old 05-20-2012, 05:06 PM Thread Starter
tweak is an unknown
i am considering an E tune through ia performance. they offer a cobb ap for 595 plus an e tune for an extra 20$.
AccessPORT, access, port, flash, ecu, chip, programmer, tuner
tweak is offline
