-   -   sputer sputer.......fine (http://www.wrxtuners.com/forums/f51/sputer-sputer-fine-33582/)
mikemar 02-12-2013 02:24 AM
i was told that this could be a boost leak or a vacume leak it feels more like a lost cylinder to me! i just bought a one owner 2002 rex 150k miles, one owner, clean title, no problems or obvious leaks under the car. i can hear the tubo just fine but it coughs and sputters some times and the check engine light comes on. i can push in the clutch let it idle down and it's fine and the check engine light goes out. please help me with this!
pzr2874 02-12-2013 06:32 AM
coughs and sputters when?
on WOT ?
Also see if the ECU stored any of those CEL's
mikemar 02-12-2013 12:05 PM
hooked it to my buddies reader. it's a miss fire cylynder 2,3 at 1300 rpms determined its the coil packs if you think its some thing else any info would help.
pzr2874 02-12-2013 12:24 PM
I'd try the plugs first. CP's are a bit expensive as a rule out DX.
mikemar 02-12-2013 02:16 PM
thanks...... will do gonna..... run platnums if it persits then i will go to the CP s found a loose vacume line just above #4 cylinder too....rehooked it maybe that played a part in all of this
pzr2874 02-12-2013 03:06 PM
Try the plugs and gap them PERFECTLY according to your tuner/map/mods/etc....
mikemar 02-13-2013 02:03 AM
someone mentioned to me a faulty alternator or bad battery could cause this too? and there are no mods on this car......yet
pzr2874 02-13-2013 06:14 AM
I'd try the plugs first (since they might need to be done anyways). Then you can switch the CP's around to see if the misfire moves with the packs.
mikemar 02-13-2013 12:37 PM
thanks
BLAZE2099 02-13-2013 10:15 PM
Watch how you build a Wrx with that mileage. Be careful.
mikemar 02-14-2013 10:12 AM
thanks for all the help. while i was changing the plugs t found the problem......broken retainer clip on a CP harness! all that worry over a 1 cent zip tie fix the plugs were all fairly good. the timing belt has been changed @ 95k i only run 93 octaine i hope i have no more problems to contend with!
pzr2874 02-14-2013 10:27 AM
Awesome news.
