Old 05-10-2008, 09:59 PM   #1 (permalink)
crazilywrx's Avatar
Reputation: crazilywrx is an unknown
So I bought a 2002...
Hey everyone,
I decided to buy that 2002, and had a quick question about the way the clutch is supposed to feel in that car. I've had a few hydraulic clutch vehicles and the pedals usually depress like butter. But in my new 2002 WRX, the clutch feels a lot tougher to depress. It feels more like a cable clutch to me. Is this normal?? Is anyone out there familiar with the feel of hydraulic clutches and cable clutches that can help me decide whether or not this is normal??
Old 05-10-2008, 10:06 PM   #2 (permalink)
SuBeast's Avatar
Club Region: NorCal
Reputation: SuBeast is on thin ice
What do you mean? The clutch pedal is stiff?? Could need a new clutch line? i don't know, i don't really understand what you're asking
99' Jetta VR6
-SDP Intake
-Suitcase delete
-Royal Purple
-Synchromesh
Online
Old 05-10-2008, 10:11 PM   #3 (permalink)
crazilywrx's Avatar
It's stiffer then I am normally used to. Every hydraulic clutch car I've ever driven, you can depress the clutch pedal with 0 effort. This one seems to have more resistance while trying to depress the pedal. Is there a way to bleed the hydraulic clutch system? Did this help clear up the problem?
Old 05-10-2008, 10:39 PM   #4 (permalink)
SuBeast's Avatar
Club Region: NorCal
Oh ok, so what if it feels stiffer, every car has a different clutch feel... Now, if you have had the car for a while and now the clutch feels tighter, then there might be something up, but if it just feels different then all the other cars you've driven, could just be because it has a different clutch in it.... Possiblly an upgrade clutch. I've heard that upgraded clutches can do this...
99' Jetta VR6
-SDP Intake
-Suitcase delete
-Royal Purple
-Synchromesh
Online
Old 05-10-2008, 10:49 PM   #5 (permalink)
crazilywrx's Avatar
I know that it may be normal, but I found it slightly odd that every hydraulic clutch I've ever driven has a smooth clutch with no resistance in the pedal. I only bought this car a few days ago, so I wouldn't know if there has been any change and this is the first WRX I've driven. I think I need to feel the clutch dis-engagement in another WRX to see if it's just me.
Old 05-11-2008, 03:40 AM   #6 (permalink)
Reputation: johnyBlack is an unknown
stage 2 stage 3 etc clutches will be alot harder to push down, but the release should actually kick your foot back, so no i do not think he has an upgrade, check your lines.
Old 05-11-2008, 06:44 AM   #7 (permalink)
crazilywrx's Avatar
Is there a way to bleed the clutch fluid??
Old 05-11-2008, 09:00 AM   #8 (permalink)
Reputation: dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to
It's normal.AWD cars have a pretty stiff clutch basket.The master cyclinder for the clutch is kinda under the intercooler below the brake master cylinder.
Aarg matey!
ECU Pirated by RomRaider
Old 05-11-2008, 10:01 AM   #9 (permalink)
Reputation: nagyhead is known to be trustworthy and helpful nagyhead is known to be trustworthy and helpful nagyhead is known to be trustworthy and helpful
you could also have a worn pressure plate. that could cause a stiffer feel.
Old 05-11-2008, 11:37 AM   #10 (permalink)
Reputation: baller_v24 is a helpful contributing member
+1 with dumdum, these cars come with pretty long lasting clutches, it is not your average clutch. i thought the exact same thing when i first drove my bugeye. i have yet to drive any other car with a stock clutch that's anywhere near ours.
Old 05-11-2008, 07:57 PM   #11 (permalink)
Reputation: Tsuiso is an unknown
Send a message via AIM to Tsuiso Send a message via MSN to Tsuiso Send a message via Yahoo to Tsuiso
The last time I had this problem was with my 240SX. The clutch was difficult to compress so I changed the line to a steel braided unit. Immediately after bleeding the line I noticed a very substantial difference. The clutch pedal felt nearly identicle to the gas pedal.
Although this case was NOT with a WRX, the insight may still be useful.
Old 05-11-2008, 08:10 PM   #12 (permalink)
crazilywrx's Avatar
Thanks, I will give it a try. Has anyone changed their clutch line? I was wondering if there was any difference between the STI, Mach V, or Goodrich braided lines. I also want to buy a repair book for the car. Haynes, Chilton, Bentley?? Which one is the most detailed or best for repair on our vehicles?
Old 05-12-2008, 10:48 AM   #13 (permalink)
I have always personally always bought haynes for any of my vehicles. It isnt extremely detailed about HOW to do something exactly but it tells you exactly what needs to be done and gives different ratings. Plus its like $20 lol.
If the clutch line is anything like the two ive done in my life (replaced one with stock lol it was cut) then it should be pretty easy. Hard to say!
Old 05-12-2008, 12:31 PM   #14 (permalink)
go to the subaru dealer and ask to test drive a WRX and see if it feels the same. Hell, you probably just need to sit in one and depress the petal to see if it's anything abnormal or just something you're not used to yet.
It is pretty stiff though right from the factory.
Engineers can't spell, sorry!
Old 05-12-2008, 04:29 PM   #15 (permalink)
crazilywrx's Avatar
Thank you all for your help. I love message boards cause you always get more help quicker then if you went to a shop or a dealership. I'm going to do a forum search on the steel braided clutch lines but if anyone has any input as to which one is better, let me know.
