safe psi - Subaru WRX Forum
post #1 of 11 Old 10-28-2003, 07:59 AM Thread Starter
drunkmonk is an unknown
Question safe psi
Hi everyone, i'm new with my 2002 wrx and still not a great mechanic. I just ordered an Apexi Gt cat back exhaust, and a Aem shortram intake. The next thing I plan on doing is getting is a manual boost controller/guage. I was wondering whats a safe yet effective psi i should raise the turbo to? Thanks for your help and comments.
drunkmonk is offline
post #2 of 11 Old 10-28-2003, 08:18 AM
WRXblurr's Avatar
WRXblurr is an unknown
well to really turn up the boost you need a catless up pipe... with out a catless up pipe you could maby turn it up 1psi or a little bit lower.. it is really up to you.. anytime you raise boost with a catless up pipe there is a chance of a pice of the cat breaking off and damageing your turbo..
WRXblurr is offline
post #3 of 11 Old 10-28-2003, 08:21 AM
WRXblurr's Avatar
i see you live in nj.. where you buy your suby.. i got mine from somerset subaru..
WRXblurr is offline
post #4 of 11 Old 10-28-2003, 09:05 AM
Cosmo's Avatar
Images: 15
My advice is this- keep the boost at the same peak level. With a MBC, you will have more low end power since the ECU limits your boost at lower rpms. But, just make sure the peak stays at the same spot. Doing this, I went from running 9.3 at the track (1/8 mile) to running a 9.0.
Cosmo is offline
post #5 of 11 Old 10-28-2003, 12:13 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
You can go to 14.5psi. Thats what the JDM spec run so its fine.
Che
Tut4u2 is offline
post #6 of 11 Old 10-29-2003, 07:51 AM Thread Starter
thnaks for the info, and i live maybe 10 minutes away from the somerset subaru dealer for whoever asked.
post #7 of 11 Old 10-29-2003, 07:53 AM Thread Starter
I got my suby used from some guy in new york
post #8 of 11 Old 10-29-2003, 07:56 AM
Cosmo's Avatar
Images: 15
Uhhh.... no. The JDM car uses a different turbo, and is tuned to run on the 100 octane pump gas they use.
Cosmo is offline
post #9 of 11 Old 10-29-2003, 10:13 AM Thread Starter
o really......I think ill get a uppipe before i boost it up a psi then
post #10 of 11 Old 10-29-2003, 10:28 AM Thread Starter
I also heard if you get some new injectors and a new fuel pump you can safely raise your boost even more. If this is true....how much would be good? thanks again
post #11 of 11 Old 10-29-2003, 11:24 AM
BlueDemon's Avatar
BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
Yes you can raise your boost more if you got a new fuel pump and injectors, however you MUST have engine management to run the new injectors or else you won't be going anywhere.
Blue
BlueDemon is offline
