Question with exhaust - Page 2 - Subaru WRX Forum
post #16 of 30 Old 07-27-2009, 01:54 PM
if you just change the catback there won't be any true power gain...you'll just get the subaru exhaust note...all the power gain is in the downpipe...but you will need to get a tune to see the full benifit...and changing the up pipe in a 02-05 WRX removes the cat before the turbo which has been known to fall apart and get sucked into the turbo...and by doing this you will probably notice a little bit quicker spool time
post #17 of 30 Old 07-27-2009, 02:16 PM Thread Starter
tilem is an unknown
So if I understand, if I keep the stock up pipe and I change the catback and the downpipe, I will get a better sound and just a little more power ?
(sorry for my english, I speak french)
tilem is offline
post #18 of 30 Old 07-27-2009, 02:33 PM
yup thats right...you probably won't even notice the power gain because the stock CBE flows pretty well all of the congestion is in the Downpipe...but you if you do have an 02-05 WRX (i cant tell because you haven't listed your car) you really should consider swaping up-pipes...the pre-turbo cat is bound to start to disintigrate one of these days and ruin your turbo
post #19 of 30 Old 07-27-2009, 02:50 PM
The main RESTRICTION is the DOWNPIPE.
post #20 of 30 Old 07-27-2009, 04:55 PM Thread Starter
tilem is an unknown
So, for not broke the turbo, its better to change the up pipe too ?
tilem is offline
post #21 of 30 Old 07-27-2009, 05:23 PM
yes depending on the year of your car it is a good plan to change the up-pipe
post #22 of 30 Old 07-27-2009, 06:48 PM
airplnmdls's Avatar
airplnmdls is an unknown
Send a message via AIM to airplnmdls
well I have a 2007 WRX Wagon...is it a good idea for me to replace the up pipe? Also if i wanted an aftermarket exhaust similar to SPT's, which one should I look at?
airplnmdls is offline
post #23 of 30 Old 07-27-2009, 09:07 PM Thread Starter
tilem is an unknown
If its a 2002 or 2003 ?
**What si the difference of a 2002 and a 2003 WRX ?
tilem is offline
post #24 of 30 Old 07-27-2009, 09:23 PM
No theres no real benifit for you to replace your up-pipe because you have an 07 which does not have a cat in the up-pipe
there is no difference in the 2002-03 models with regards to the exhaust
post #25 of 30 Old 07-27-2009, 11:25 PM Thread Starter
tilem is an unknown
Ok, but do I need to change the up pipe on a 2002 or 2003 ?
tilem is offline
post #26 of 30 Old 07-27-2009, 11:27 PM
For stage 2 no, for upgraded turbos, yes.
06+ wrx and 04+ STi guys, you don't have a cat in your up-pipe so that does not apply. 02-05 WRX guys only.
post #27 of 30 Old 07-27-2009, 11:41 PM Thread Starter
tilem is an unknown
Ok guys, you need to explain me something,!Cry! I see every where «Stage2» «Stage3» «Stage4»...But what thats mean ??
Whats "Stage.." mean ?
Im lost each time I see that
Thank you guys, now I will stop doing nightmare !Laugh!
tilem is offline
post #28 of 30 Old 07-27-2009, 11:42 PM
Generally people go by the stages defined by COBB...
Stage 1: Stock car with reflash
Stage 2: Turbo Back Exhaust (TBE) with reflash
post #29 of 30 Old 07-28-2009, 09:54 AM Thread Starter
tilem is an unknown
Ok, but what you win the get a Stages ?
tilem is offline
post #30 of 30 Old 07-28-2009, 02:48 PM
CobbTuning.com - 02-03 AccessPORT
