» Sponsor Links
»Garage Storage and Cabinets
Old 09-18-2005, 03:45 PM   #31 (permalink)
Ian
Ian's Avatar
Car: 04 WRX
Send a message via AIM to Ian
Update on my mods
Removed emblems on the trunk
STI engine pitch stop mount
STI tranny mount
And FINALLY Helix DP
For got to mention Red Line tranny and rear diff. fluid
Too be continued...
Old 10-26-2005, 05:05 PM   #32 (permalink)
ENGINE:
port/polished ceramic coated TD04
port/polished throttlebody
port/polished ceramic coated exhuast manifolds
Perrin catch can
Perrin radiator shroud
Walbro 225 pump
BPM TMIC
GT-Spec STi air splitter
Samco radiator hoses
Denso Iridium plugs
ground mod
Injen crossover pipe
APS Turbo inlet pipe
APS ceramic coated up-pipe
Speedmonkey heat sheild
Cobb AP stage ll
Helix catted DP
Autospeed catback
stock airbox with 4" velocity stack
GREEN drop in filter
TRANNY,TIRES,BRAKES,WHEELS,SUSPENSION
Racing Brake rotors
Cusco brake cylinder support
Goodridge braided lines
Whiteline steering bushings
Whiteline subframe locking bolts
Hawk HPS pads
Nrg H brace
front and rear strut tower bars
Eibach Pro kit
KYB AGX struts/shocks
Energy Suspension urethane kit
ACT Streetlite flywheel
Spec stage 1 clutch
Perrin short shifter
Kartboy shifter bushing
Rota 17" Attack
Falkien ZE 512 225/45/17
INTERIOR
Omori boost,egt,oil pressure gauges
Subaru/MOMO shift knob
Subaru all weather mats
PSI3 data analyzer
EXTERIOR
Kartboy Hella/PIAA light brackets
Hella 500 fog (ambers)
STi hood scoop
Morette lights
STi grill
Hella Supertones
UPGRADING TO SOON
tumbler deletes w/ Hondata phenolic gaskets
Extrude Honed intake manifold
Protune
Old 10-27-2005, 12:05 PM   #33 (permalink)
Timeslip: 9.999 @ 100
Reputation: IppoJ is an unknown
Engine:
PDE Up-pipe
HKS Down-pipe
Cobb rear box and rear pipe (catless)
Cobb Stage 2 AccessPORT
Lightened pulley
Beru Ultra-X colder plugs
grounded
K&N drop in
P&P'd throttle body
radiused/polished intercooler inlets/outlets
Silicone "Y"
Silicone MAF hose
(soon to be installed) P&P'd TD04, Swain coated.
Suspension, Tires, Brakes, Wheels:
Prodrive springs
Kartboy SS
Kartboy shifter bushings
B&M "Stick Shift" synthetic trans/diff fluid
Goodrich SS brake lines
Axxis MM
Valvoline Synpower fluid
Rotora slotted discs
Hardened trans mount
17x8" Rota Torques in hyperblack
235/40 17 Yoko ES100
STi replica front and rear strut bar
Silver painted calipers
Alpine Green rotor hats
Exterior:
Cleared headlights
blacked out side markers
debadged
Interior:
Matching dead pedal (Razo)
Momo Shift Knob
Leather shift boot and arm rest
Gentex auto dim/compass/temp/homelink mirror
....I'm probably forgetting something
Old 11-03-2005, 10:01 AM   #34 (permalink)
Reputation: scoobydoo03 is an unknown
myo4 WRX:
vf34 turbo
sti8 intercooler
aps cold air induction
gfb dump valve
walbro fuel pump
unichip
hks hi power zorst and hks down pipe
hks ceramic coated headers
hks iridium spark plugs
knock link sensor
18' oZ rims with Toyo t1r's
eibach springs
carbon fibre wing extensions
sti8 bonnet scoop
sti8 fog light covers
sti8 air damps
Old 11-03-2005, 10:05 AM   #35 (permalink)
ManicsWrX's Avatar
Reputation: ManicsWrX is more helpful than not
you say your 04 but in ## pro says 03...Lol pssst fix that
Chris- ▼SùbiΣ Mäƒiä▼
242 AWHP / 318 TQ
Old 11-30-2005, 11:09 PM   #36 (permalink)
stileguy's Avatar
Reputation: stileguy is an unknown
MY 00 WRX STI Version 6
engine:
All stock STI equipment (lightweight valvetrain with bucket on shim solid lifters, hollow camshafts etc)
Custom 3' turboback exhaust and Drift stainless muffler
Custom stainless cold air intake with k&n filter
custom parrallel fuel rails
modded sr20 injectors (800cc)
Sard Racing fuel pressure regulator
genuine oversize STI forged pistons
4340 forged conrods
STI version 6 cams
mild clean up of ports on stock heads
ported and matched engine pipes and 2' custom up-pipe
balanced rotating assembly (crank,rods,pistons,flywheel,clutch,harmonic balancer)
portmatched intake manifold
HPC coated inside and out mild steel intercooler piping
PWR front mount intercooler
stock recirculated STI bov controlling boost pressure via boost ebc in ecu (bleeds off excess volume) (for more details on how this works read "fixes for compressor surge" thread)
Link replacement engine management (all tuning done by me on road via laptop)
TDO6H-T04E 57 trim hybrid turbo with wastegate deactivated (24 psi) similar to fp green but bigger comp wheel
450hp high torque clutch (modified pivot points on stock pressure plate to give 2700lb clamp)
stainless oil catch can
BPM silicone turbo intake
8mm spark plug leads
ngk bcp7es-11 plugs
earth wires kit
Wheels, Suspension & Brakes
stock STI (19mm front swaybar/20mm rear, carbon fibre strut tower brace, agx struts with STI valving and 18mm lowered sti springs)
DBA 4000 series slotted front rotors with ds2500 pads all round and RBF 600 motul fluid
2005 WRX 17x7 high black Stock Wheels with RE 070 potenzas
Interior
Single RPM 4 point Harness for Driver
Apexi elm boost gauge
self turned alloy shift knob
Stock STI short shift kit
Alpine MP3 head unit, alpine 50wrms amp, 6.5' Infinity Kappa splits, JBL coaxials
stock sti seats
Limited run number plaque (64 of 400)
Exterior
Aspen White
stock STI wrc spoiler, front splitter and skirts
custom door decals and 206kw decal on rear similar to jdm models (actually has 300kw hahahahah)
Old 12-04-2005, 07:42 PM   #37 (permalink)
Lost One's Avatar
Reputation: Lost One is an unknown
Engine:
Invidia N1 catback
Helix downpipe with high flow cat
Helix flex uppipe
UTEC
None (til Spring )
Exterior:
JDM STi hood scoop
Black mesh foglight covers
Subaru black stainless front license plate mount
Custom JDM replica front license plate
Interior:
Omori electric boost and EGT gauges
Autometer gauge cluster pod
Innovate LC-1 wb O2 with XD-1 digital gauge
Blitz DC IV Turbo Timer
Old 12-07-2005, 02:27 AM   #38 (permalink)
eighth08's Avatar
Car: 05 WRX
Club Region: NorCal
Reputation: eighth08 is more helpful than not
Send a message via AIM to eighth08
my mods lol
tsudo catback
cusco rearsway with pillowball endlinks
k&n dropin filter
toyo proxes 4 225/50/16
tada!!!!! thats it right now! i keep it real guys..
soon:
turboback catless (not sure on brand yet)
cobb accessport/custom tune
IHI vf34 turbo with walbro pump/injectors pinkies
helix uppipe
helix dna sport coilovers
larger TMIC
perrin crank pulley
rear diffuser
frontsway/endlinks
many advanced support pieces for the under area.
greg
Gregory-
keep it in the dirt.
Old 12-27-2005, 03:48 PM   #39 (permalink)
Car: 05 WRX
Reputation: krieger9 is an unknown
my 04 wrx
Power Mods:
-AEM intake (came with car)
-3" SS Cat-back (type unknown, came with car)
-3" SS DP Generic Ebay
-SS UP pipe Generic Ebay
-18x12x3 Intercooler custom fabbed to sit top-mount by Krieg Motorsports(me) and TDC Tuning. Custom 2.5" alum intake plumbing appox 18" total (very short) from turbo to intake, plus core.
-34mm Re-circ valve Krieg Motorsports.
-VF-34 Turbo
-Modded Injectors TDC Tuning
-Accessport Ecu Custom Map by TDC Tuning Base map makes 285.6 whp @17.5psi, dyno'd at TDC Dyno = Land and Sea, Eddy current, awd roller dyno.
Handling:
Toyo T1-S, stock size, on stock rims.... hey they were free!
Suspension the stock junk... =/
Old 05-01-2006, 06:48 PM   #40 (permalink)
awd>fwd's Avatar
Reputation: awd>fwd is an unknown
My mods....Are you sure you're ready for this?
Engine- Stock
Suspension- Stock
Exterior- Stock 17" Enkei's painted Graphite grey (looks pretty good)
Debadged trunk lid, WRX, SUBARU, and IMPREZA are gone, IMPREZA is now mounted on my tool box at school.
Interior- Stock + my messiness!
On the way (hit customs yesterday!)- Helix Turbo back exhaust
On backorder- Cobb AP (not sure on the status at this point)
Brent
Cool people have coilovers.
▼SùbiΣ Mäƒiä▼
Old 05-02-2006, 12:48 AM   #41 (permalink)
WrXDrivR's Avatar
Reputation: WrXDrivR is an unknown
Engine:
AEM CAI (yes, I know...)
HKS Hi-Power CBE
eBay "STi" Grounding kit (shipped today)
Exterior:
WRX wing
soon-to-be de-badged trunk
Interior:
Subaru sub
Subaru security shock sensor
COBB short shifter (love it)
Suspension (ect.):
RE92s FTW!!
stock (for now...)
Old 05-02-2006, 09:42 PM   #42 (permalink)
Ian
Ian's Avatar
Car: 04 WRX
Another update!
STI hood scoop to go with my freshly painted front end ( hood, fender, bumper and doors) since they were chipped really bad.
Koni inserts (struts)
Sirrius radio, F/R door speakers and 1 10 inch sub with an a 5 channel amp
More to come.....
Old 05-30-2006, 09:59 PM   #43 (permalink)
Reputation: TR06MONSTER is an unknown
Engine-
COBB Accessport Stage II
Greddy EVO 2 catback
GT SPEC headers W/ uppipe
Perrin Short Ram Air Intake with big MAF sensor
Greddy FMIC
*still deciding on VF39 turbo or 20G*
Audio-
Pioneer cd. deck
MTX 5500 10inch sub in ported box
thats it for now......
Old 05-31-2006, 09:02 PM   #44 (permalink)
Ian
Ian's Avatar
Car: 04 WRX
Cusco front lip spolier
Cusco turbo heat shield and radiator shroud
DIY mod, cleared head lights or removed the orange reflectors
Areo bits, center under covers ( factory STI part )
Old 06-05-2006, 02:36 PM   #45 (permalink)
500whpRex's Avatar
Car: 04 WRX
Club Region: NorCal
Reputation: 500whpRex is an unknown
Send a message via AIM to 500whpRex
Engine:
Upipe
Turboback
Turbosmart Manual Boost Controller
Blitz Turbo Timer
HKS Turbo Timer Harness
Denzo Iridium Plugs
STi 2.5 Short Block
Wiesco Pistons
Forged Crank
Forged Cams
ACT Clutch
Turbonetics T3/T4 (600 hp)
Top Mount Intercooler
Tial WasteGate
785cc Fuel Injectors
Cold Air-Intake
Fuel Pump
Turbosmart Bypass Valve
Tuning by www. Ultimate-Racing.com
Suspension, Brakes, Tires, Wheels:
Stock
Exterior:
Polished Hood Pins
Debadged Rear
Interior:
Blitz Turbo Timer
"Your WRX Looks Stock from The Outside."
