If your anything like me, you hate trying to find Subaru part numbers when ordering. The purpose of this thread is to list commonly replaced and used Genuine Subaru parts and their respected numbers for easy reference. This thread will be a continual work in progress so be patient and understanding. Always double check your number and application before purchasing. Subaru is continually changing part numbers and one part may fit many different applications. I only want to list numbers and fitment you are absolutely, 110% sure is correct. So if you bought a gasket for your 07 wrx but think it will fit all 02-07 WRX and STI don't say it will unless you have confirmed it in a legitimate way (online part number search, personal experience, exct...). If you have a contribution you can post it in the comments and i will add it to the origional post or you can message me or maybe a mod if they are willing to help upkeep on this. Look to make sure it is not on the list before contributing in a effort to avoid double post. If you see an error or know a part is confirmed to fit something else then please share. Do not use this thread as a parts bible. Use it as a general reference and starting point on hard to find numbers.
ENGINE
VF52 Turbocharger: Confirmed on 09-14 WRX
14411AA800
PVC kit: Confirmed on late 03-07 WRX & 04+ STI
11815AB711
STI connecting rods: Confirmed on all 04-12 STI's
04-07 STI 12100AA181
08-12 STI 12100AA291
Shortblock (EJ255 with 24cc piston dish): Confirmed on most 2.5L WRX, Legacy GT, & Outback XT
10103AC040
STI EJ257 Blank cylinder heads: Confirmed on STI years below
(2004)
11039AB650 -- Cylinder Head Case RH
11063AB120 -- Cylinder Head Case LH
(2005 - 2006)
11039AB910 -- Cylinder Head Case RH
11063AB330 -- Cylinder Head Case LH
(2007)
11063AB280 -- Cylinder Head Case LH
11039AB860 -- Cylinder Head Case RH
(2008 - 2010)
11063AB480 -- Cylinder Head Case LH
11039AC070 -- Cylinder Head Case RH
Cam gear/sprocket (Left side exhaust): Confirmed on 02-05 WRX 2.0
13054AA033
OEM platinum spark plugs: Confirmed on 02-05 WRX (2.0 only)
22401AA530
OEM spark plugs: Confirmed on 04-07 STI, 06-07 WRX,
22401AA630
Oem spark plugs: Confirmed on 05-09 Legacy GT
22401AA670
Timing belt idler pulleys: Confirmed on all turbo Subaru EJ engines
Cogged Pulley – 13085AA080
Smooth Pulley – 13073AA142
Small Pulley for 2002 – early 2003 WRX – 13073AA200 (old style pulley which has been revised)
Small Pulley for Late 2003 on Turbo EJ Series Engines – 13073AA230 (updated pulley which can be used on 02-03 with the purchase of longer bolt. See engine hardware.)
Timing belt tensioner: Confirmed on 2002+ WRX, 2004+ STI, 2005+ Legacy GT, and 2004+ Forester XT.
13033AA042
Timing cover right front: Confirmed on 08+ STI
13572AA120
Timing cover Left front: Confirmed on 08+ STI
13574AA120
A/C belt tensioner plastic adjuster: Confirmed on all 02-07 WRX & STI
73134AC001
Cam gear/sprocket (Left side AVCS intake): Confirmed on 04-07 STI, 06+ WRX, 05+ legacy GT, 04+ Forester XT
13322AA001
Cam gear/sprocket (Left side intake): Confirmed on 02-05 WRX 2.0
13055AA070
Cam gear/sprocket (right side exhaust): Confirmed on 02-05 WRX 2.0
13049AA041
Cam gear/sprocket (right side intake): Confirmed on 02-05 WRX 2.0
13044AA061
Cam gear/sprocket (Left side AVCS exhaust): Confirmed on 04-07 STI, 06+ WRX, 05+ legacy GT, 04+ Forester XT
13054AA033
Cam gear/sprocket (right side AVCS intake): Confirmed on 04-07 STI, 06+ WRX, 05+ legacy GT, 04+ Forester XT
13320AA001
Ej257 shortblock (case halves, rods, crank, and pistons fully assembled): Confirmed on 2004-2008 STI
10103AC030
Right intake camshaft: Confirmed on 2006 STI
13031AA352
Right exhaust camshaft: Confirmed on 2006 STI
13034AA352
Left intake camshaft: Confirmed on 2006 STI
13037AA352
Left exhaust camshaft: Confirmed on 2006 STI
13052AA352
AVCS cam gear (exhaust left side): confirmed on 2008+ STI
13323AA001
AVCS cam gear (intake left side): confirmed on 2008+ STI
13322AA001
AVCS cam gear (exhaust right side): confirmed on 2008+ STI
13321AA001
AVCS cam gear (intake right side): confirmed on 2008+ STI
13320AA001
Cam gear/sprocket (right side AVCS exhaust): Confirmed on 04-07 STI, 06+ WRX, 05+ legacy GT, 04+ Forester XT
13049AA041
Shortblock engine with heat treated crankshaft (case halves, rods, pistons, & crankshaft fully assembled): Confirmed on 2010 STI
10103AC050
Crankshaft (79mm stroke & 5th position thrust): Confirmed on 04-07 STI
12200AA370
Crankshaft (Heat treated): Confirmed for 2010 WRX STI EJ257
The Subaru Part # for this Heat Treated Crank is 12200AA330, superseded from the 12200AA430 which was Nitride Treated.
Crankshaft: This is the OEM Crankshaft that came in the 2004 - 2005 Ej20 WRX. The main difference between this, and the earlier Crankshafts is that this one came cross-drilled from the factory for better lubrication. This crankshaft has a stroke of 75mm, and the thrust bearing is in the 5th position.
12200AA240
EJ257 case halves (empty): The case is the same on all USDM STI's from 2004 - 2010, and is also the same block found in the EJ255 engine found in the 06+ WRX and 05+ Legacy GT.
11008AA930
ENGINE-OIL SYSTEM
GENUINE SUBARU 5W-30 AND 0W-20 SYNTHETIC MOTOR OIL: Check owners manual
5W-30 Gallon Subaru Part # SOA868V9285
5W-30 Quart Subaru Part # SOA868V9280
0W-20 Quart Subaru Part # SOA868V9300
Oil filter: Confirmed on 06 WRX
SUB15208AA12A
Oil filler tube O-ring: Confirmed on 04 WRX
21191KA000
Oil separator cover gasket: Confirmed on 02-05 WRX
21191KA000
Oil pickup: Confirmed on 02-07 Wrx and STI
15049AA110
Oil baffle: See below
2002 – 2005 2.0 liter WRX – 11036AA001
2004+ 2.5 Liter STI – 10915AA010
Oil pan: Confirmed on 06-07 WRX and STI
11109AA151
Oil cooler: See below
2002 - 2005 SUBARU WRX EJ205 , 2004 - 2007 STI EJ257, & 2005-2009 Legacy GT
21311AA051
2006 - 2007 SUBARU WRX EJ255
21311AA071
2008 - 2012 SUBARU STI
21311AA120
Oil dipstick: Confirmed on 06-07 WRX and STI & 2013 Forester XT
11140AA150
10mm oil pump: Confirmed on 02+ WRX & 04-07 STI
15010AA108 supersedes to 15010AA300
ENGINE-FUEL SYSTEM
Fuel filter: confirmed for 06-07 WRX
42072FE020
FUEL FILTER: confirmed on 02/03 wrx
42072PA010
ENGINE-COOLING SYSTEM
Water pump: confirmed for 05-07 WRX and 04-10 STI
21111AA240
Water pump: Confirmed on 02-04 WRX
21111AA026
Water pump: Please note that this is only for the 2008 - 2014 WRX because it does not have the outlet for the factory oil-cooler.
21111AA250
Thermostat: Confirmed for all 02-14 WRX & STI
21200AA072
Upper radiator hose: Confirmed on 02-07 WRX & STI
45161FE050
Lower radiator hose: Confirmed on 02-07 WRX & STI
45161AE020
Cooling system conditioner: Should be used in all models but, check with your dealer or owners manual
SOA635071
Subaru long life coolant: check your owners manual for compatibility
SOA868V9210
ENGINE-ELECTRICAL
Front o2 sensor: confirmed on 02-05 WRX
22641AA042
Rear o2 sensor: Confirmed on 02-07 WRX & STI
22690AA520
ENGINE-MOUNTING, HARDWARE, & BRACKETRY
Crankshaft pulley bolt: Confirmed on 06 WRX
12369AA011
Galley plug with sensor bung: Confirmed on all EJ engines
11024AA210
Head bolt: Confirmed on all turbo EJ engines
11095AA042
Head to block straight dowell pin: Confirmed on all EJ engines
804014060
Exhaust flange nut (works on uppipe to header collector, downpipe to turbo, uppipe to turbo, & crossover pipe to header collector): Confirmed on all Subaru turbo models. Pictured in post #15
902370029
Exhaust flange bolt ( works on uppipe to header collector ,downpipe to turbo, & crossover pipe to header collector): Confirmed on all Subaru turbo models. Pictured in post #15
44059aa030
Long bolt for small idler pulley: This the bolt that attaches the small idler pulley for the timing belt on the Subaru EJ series engines. From 2004+ the small idler pulley was re-designed to incorporate 2 bearings instead of 1. This vastly improved the small idler pulley's reliability, but it requires a longer bolt.
This is that bolt.If you are up-grading the small idler pulley on your 2002 - 2003 WRX to the newer 2004+ small idler, pulley, this is the bolt that you will need to make that work.This is also the bolt you will need if you are using the 2004+ Gates Racing Kit if it is for a 2002 - 2003 WRX.
800708460
Case Transmission guide stud (goes in block to line up trans): Confirmed on all EJ20, EJ255, & EJ257
800910470
Heat shield bracket (holds turbo heat shield in place): Confirmed on 02-07 WRX
44021AA012
Oil filter post: See oil cooler part#'s below for fitment
OIL FILTER POST (FOR 21311AA051 AND 21311AA120)
21317AA022
OIL FILTER POST (FOR 21311AA071)
21317AA041
Crankshaft woodruf key: Confirmed on all Subaru crankshafts
804505060
AVCS and non-AVCS cam gear bolt:Confirmed on 04-07 STI, 06+ WRX, 05+ legacy GT, 04+ Forester XT, 02-05 WRX 2.0
13199AA000
ENGINE-GASKETS, SEALS, O-RINGS, ECXT...
REAR ENGINE RE-SEAL KIT: This kit includes everything you need to reseal the whole back side of the motor, which you have access to during clutch installation. Fits most turbocharged Subaru engines.
806786040 - Rear Main Seal
11831AA210 - Rear Access Panel
800406140 (x5) - Access Panel Screws
800406150 - Access Panel Locking Screw
806931070 - Driver's Side O-Ring
Water pump gasket confirmed for 02-14 WRX, 04-10 STI, 05-09 Legacy GT, & 04-08 Forester XT
21114AA051
Oil cooler gasket: Confirmed on all turbo EJ engines
21370KA001
Valve cover bolt seals: Confirmed on 02-05 WRX
13271AA071
Intake manifold to TGV gasket: Confirmed on all 02-07 WRX & 04-14 STI Pictured in post #17
14075aa161
TGV to head gasket: Confirmed on all 02-14 WRX and STI pictured in post #17
14035aa421
Master gasket kit: Confirmed on 93-01 Impreza (see below)
1993-1998 1.8L ENGINE
10105AA180
1994-1998 2.2L PHASE I
10105AA200
1998 2.5L (DOHC) PHASE I ENGINE
10105AA401
1998-2001 2.2L PHASE II
10105AA300
1999-2001 2.5L PHASE II (SOHC)
10105AA860
Master gasket kit WRX: There are different kits depending on the year of your car, so please make sure you choose the correct year.Please note: The year splits are not set in stone, so if you are unsure which kit you may need, please verify with your VIN.
2002-EARLY 2003 WRX
10105AA351
2003 - 2005 WRX
10105AA560
2006-2007 WRX 2.5L
10105AB010
2008 SUBARU WRX 2.5L
10105AB070
2009 - 2013 SUBARU WRX 2.5L
10105AB230
Master gasket kit: Confirmed on 2005 LEGACY GT
10105AA720
EJ257 master gasket set: Depending on what year STi you have, you will need one of three versions of the Master Gasket Set for the STi. The year cut-offs are not set in stone, so if you are not totally sure which version you need, just check with the last 8 digits of your VIN number and you can figure out which version you need.
The 2004 - 2006 STi uses Part # 10105AA590
The 2007 STi uses Part # 10105AB080
The 2008 - 2010 STi uses Part # 10105AB200
Half moon seal for cylinder head: Confirmed on all EJ engines
11051AA070
Cam seals: Subaru has only used 2 different cam seals to date on their turbo-charged engines. One for the standard cams, and another for the AVCS cams. The two Subaru Part #’s are as follows:
Non-AVCS Cam Seal – 806732160
AVCS Cam Seal – 806742160
If you are not sure which seal you need, here is a list of the most common applications.
2002 – 2005 WRX (EJ205)
Intake and Exhaust Cam Seals are the same – 806732160 Non-AVCS (4 total)
2006+ WRX (EJ255)
Intake Cam Seal – 806742160 – AVCS (2 total)
Exhaust Cam Seal – 806732160 – Non-AVCS (2 Total)
2004 – 2007 STI (EJ257)
Intake Cam Seal – 806742160 – AVCS (2 Total)
2008+ STI (EJ257)
Intake and Exhaust Cam Seals are the same – 806742160 – AVCS (4 Total)
2004 – 2008 Forester XT (EJ255)
2005 – 2009 Legacy GT (EJ255)
Bypass valve gasket: Confirmed on 02-05 WRX & 04-14 STI
21896AA072
Donut exhaust gasket: Confirmed on all turbo models
44022AA122
Downpipe to turbo gasket: Confirmed on all 02-07 WRX & STI
44022AA180
Twin scroll downpipe to turbo gasket: 44011FE020
Thermostat gasket: Confirmed on 06 WRX
21236AA010
Cylinder block sealing washer (goes on 6 of the case half bolts): Confirmed on all EJ20 & EJ257
11034AA010
Crankshaft oil seal front : Confirmed on 06 WRX
806733030 (photo in post #6)
Fuji bond:Subaru has two proprietary Silicone Sealants that they recommend for all required applications on Subaru Engines and Transmissions. They are called Fuji Bond, and come in either a gray, or orange.
Orange Fuji Bond is the most common, and is recommend for any surface that is in contact with oil, such as an oil pan, etc.Gray Fuji Bond is not used as much, and is used for more specific applications.
Orange Fuji bond – 004403012
Gray Fuji Bond - 004403007
O-ring cyl block (goes between oil pump and block): Confirmed on 06 WRX
10991AA001 (pictured in post #7)
Gasket exhaust crosspipe to manifold elbow: confirmed on 06 WRX
44011FE000
Gasket exhaust manifold to head: confirmed on 06 WRX
14038AA000
Head gasket: Confirmed on 02-05 WRX
11044AA483
Head gasket: Confirmed on 04-06 STI
11044AA642
Intake manifold gasket: Confirmed on 05-09 Legacy GT
14035AA492
Y-pipe gasket: confirmed on 02-03 wrx
21896AA010
TRANSMISSION & DRIVETRAIN
07 STI 6-speed transmission: Confirmed on 07 STI
32000aj350
Bushing: . This will fit in all models of the 2002-2007 Subaru Impreza. These are the bushings in the "dogbone" in the rear diff / subframe.This bushing pair came on the STi models, but will fit in the other Impreza models. It will lessen the slop in the subframe and make the car more responsive during aggressive driving. The bushings would be a worthwhile upgrade or a worthy replacement!
41322FE040
Rear diff fill plug: Confirmed on 06 WRX (R160) (picture in post #7)
807025010
Speedometer gear: Confirmed on Baja 5-speed
32714AA190
Front inner CV boot: confirmed on 06 WRX
28323ag010
Front outer CV boot: Confirmed on 06 WRX
28323ag020
CV axle grease package: All models
284595AE010
Flywheel: See below
2002 - 2005 SUBARU WRX12342AA071
2006+ SUBARU WRX
12342AA090
2004+ STI
12310AA410
2005 - 2009 SUBARU LEGACY GT
12342AA090
Pilot bearing: fits most manual transmissions 93 to present
806212020
SUBARU FLYWHEEL BOLTS
800610740
Rear differential breather: Confirmed on 02+ WRX, 04+ STI, 04+ Forester XT, & 05+ Legacy GT
38354AA002
Rear differential flange: Confirmed on all R180 STI
38358AA040
Rear differential flange: Confirmed on all R160 WRX
38358AA000
Center differential: Confirmed on all 02-14 WRX 5-speeds
38913AA100 which supersedes to 38913AA102
TRANSMISSION & DRIVETRAIN-GASKETS, SEALS, O-RINGS, ECXT...
Oil seal (goes in transmission where axle goes in right hand side): confirmed on 06 WRX
806730041 (picture in post #6)
ENGINE
14411AA800
11815AB711
10103AC040
(2004)
(2005 - 2006)
(2007)
(2008 - 2010)
13054AA033
22401AA530
22401AA630
22401AA670
13033AA042
13572AA120
13574AA120
73134AC001
13322AA001
13055AA070
13049AA041
13044AA061
13054AA033
13320AA001
10103AC030
13031AA352
13034AA352
13037AA352
13052AA352
13323AA001
13322AA001
13321AA001
13320AA001
13049AA041
10103AC050
12200AA370
12200AA240
11008AA930
ENGINE-OIL SYSTEM
SUB15208AA12A
21191KA000
21191KA000
15049AA110
11109AA151
21311AA051
21311AA071
21311AA120
11140AA150
ENGINE-FUEL SYSTEM
42072FE020
42072PA010
21111AA240
21111AA026
21111AA250
21200AA072
45161FE050
45161AE020
SOA635071
SOA868V9210
ENGINE-ELECTRICAL
22641AA042
22690AA520
12369AA011
11024AA210
11095AA042
804014060
902370029
44059aa030
800708460
800910470
44021AA012
21317AA022
21317AA041
804505060
13199AA000
21114AA051
21370KA001
13271AA071
14075aa161
14035aa421
10105AA180
10105AA200
10105AA401
10105AA300
10105AA860
2002-EARLY 2003 WRX
10105AA351
2003 - 2005 WRX
10105AA560
2006-2007 WRX 2.5L
10105AB010
10105AB070
10105AB230
10105AA720
11051AA070
2006+ WRX (EJ255)
2008+ STI (EJ257)
21896AA072
44022AA122
44022AA180
21236AA010
11034AA010
44011FE000
14038AA000
11044AA483
11044AA642
14035AA492
21896AA010
32000aj350
41322FE040
807025010
32714AA190
28323ag010
28323ag020
284595AE010
Flywheel: See below
2006+ SUBARU WRX
12342AA090
2004+ STI
12310AA410
12342AA090
806212020
800610740
38354AA002
38358AA040
38358AA000
