-   -   Newbie Need help/suggestion on engine swap (http://www.wrxtuners.com/forums/f51/newbie-need-help-suggestion-engine-swap-33322/)
Bell3007 11-27-2012 07:40 PM
Hi, I recently just purchased a 05 outback xt. It needs a new engine or short block, I've been juggling a few ideas and don't know the best way to go. First would a used sti engine fit and what would I be in for? Or should I go with a sti short block and what would be involved in that?
pzr2874 11-28-2012 05:50 AM
What are you going to use the car for? Daily driver? Track? Auto-x ?
brfatal 11-28-2012 07:30 AM
Just get another EJ255 block. You're looking for extra hassle with no benefit.
Bell3007 11-28-2012 12:09 PM
Mainly daily driver, but still want some power so it can be a bit of a sleeper. I looked ino an ej257 is this the right block?
mosc 11-28-2012 01:11 PM
The difference between the EJ257 and EJ255 is the heads. If you just need the short block, doesn't matter much. I think there might be some small difference I can't remember but it's minor. If you need the heads, stick with the EJ255. Your car is drive by cable, the EJ257 heads are drive by wire. The conversion is a ####tacular amount of work.
Bell3007 11-28-2012 01:48 PM
Just orders the EJ257 sb, what are good mods to have done while this thing is apart?
psinuse 11-28-2012 02:36 PM
This pistons are different in both of those shortblocks as well. 257 has 22cc dished pistons while the 255 has 24cc dished pistons.
brfatal 11-28-2012 02:40 PM
[quote=mosc;288153]The difference between the EJ257 and EJ255 is the heads. If you just need the short block, doesn't matter much. I think there might be some small difference I can't remember but it's minor. If you need the heads, stick with the EJ255. Your car is drive by cable, the EJ257 heads are drive by wire. The conversion is a ####tacular amount of work.[/quote]
EJ255 has different pistons than the EJ257. EJ255s (what he has stock) pistons have smaller dishes. It's not a huge difference. Not sure how it would affect tuning.
EJ255s are DBW as well.
psinuse 11-28-2012 03:03 PM
[quote=brfatal;288160]EJ255 has different pistons than the EJ257. EJ255s (what he has stock) pistons have smaller dishes. It's not a huge difference. Not sure how it would affect tuning.
EJ255s are DBW as well.[/quote]
:beatentod
brfatal 11-28-2012 03:50 PM
[quote=psinuse;288162]:beatentod[/quote]
You hadn't responded when I hit reply. [IMG]http://www.tiroalblancopr.net/public/style_emoticons/default/icon_bah.gif[/IMG]
psinuse 11-28-2012 04:16 PM
[quote=brfatal;288166]You hadn't responded when I hit reply. [IMG]http://www.tiroalblancopr.net/public/style_emoticons/default/icon_bah.gif[/IMG][/quote]
4 mins. prior...snooze and you lose....:D
brfatal 11-28-2012 04:43 PM
Bro, do you even lift?
psinuse 11-28-2012 04:53 PM
Lift as in weights? Yes for shifting no....lol
Bell3007 11-28-2012 09:40 PM
Looking into putting on new exhaust, found used invidia g200 of a 02 wrx, would this fit the 05 obxt or am I wasting my time?
brfatal 11-28-2012 10:42 PM
Not even remotely.
Did you cancel your EJ257 order?
