new to the subaru world Have some problems please help :) - Subaru WRX Forum: WRX Forums
» Auto Insurance
Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Newbie Forum
Old 03-01-2013, 09:21 PM   #1 (permalink)
Reputation: xxking9 is an unknown
Hello everyone i just purchased my first subaru 06 wrx from carmax yesterday, it took me a few days to get the car because they had to install a new Air pump. along with tires. when i picked up the car the check engine light was on but all the techs had gone home. i ran the code and it was a secondary air intake code and a air intake solenoid code. i cleared them and the lights stayed off for an hour or so. when i came back outside to go for another spin around the block the light was back on. after i let it warmed up i did a healthy but not retarded 1st to 2nd gear pull then....... my cruise light started flashing along with the lights that illuminate mileage and outside temp. however when the headlights are off the mileage and outside temp lights don't flash. as this is my first wrx i do not know how its is supposed to feel, but have owned several boosted cars this one seems to lag a little and kinda hesitate at first. i have looked through the forums i see alot of similar things with boost creep and aftermarket exhaust and down pipes not being tuned. My car is 100% bone stock. everything! factory minus a crap sony head unit. any ideas? i tried taking the battery loose for 30 mins and restarting it all went back to normal for a min then call came back on.
any info would help me out alot .i will have more questions but i don't want to get ahead of myself asking questions about stuff that doesn't matter until this is fixed.
Also does anyone know if i do the intake silencer mod will that terminate my warranty.
Offline   Reply With Quote
Old 03-01-2013, 11:02 PM   #2 (permalink)
Just got told its common and it sounds like im hitting fuel cut and boost spike to 15ish psi but it shouldnt if the car is as stock as it is, also possible someone left a partial tune on it when they sold it to carmax any opinions???? anyone??????? anyone?????
Old 03-02-2013, 02:44 PM   #3 (permalink)
Reputation: brfatal is known to be trustworthy and helpful brfatal is known to be trustworthy and helpful brfatal is known to be trustworthy and helpful
Clearing the CEL is pointless as that doesn't fix the cause. I can't say I've heard of a stock car overboosting and hitting fuel cut.
Old 03-02-2013, 03:34 PM   #4 (permalink)
That's the weird thing . Im guessing its the secondary air injection pump. For the cel . But as for over boost clueless
Old 03-02-2013, 05:28 PM   #5 (permalink)
06_hawk_eye's Avatar
Reputation: 06_hawk_eye is an unknown
If it's the secondary air pump might as well get the whole pump system deleted. Being that one new valve is about 250$. And there's 2 valves. I have a 2006 Wrx as well and threw a air pump valve number one stuck open. Me being new to the Subaru world replaced The first valve it did fix the problem. But now will be cleaning the engine bay out when I get my tune and having that deleted. Personally I'd just get that deleted and have the codes replaced. Others will chime in. Hope that helps sorry it was so long
Sent from AutoGuide.com App
Old 03-03-2013, 12:11 AM   #6 (permalink)
pzr2874's Avatar
Car: 2007 MazdaSpeed3
Club Region: Gulf Coast
Reputation: pzr2874 is known to be trustworthy and helpful pzr2874 is known to be trustworthy and helpful
Unplug and then plug the system back in. see if resets the valve, if not... remove the garbage.
The silencer delete ill not mess with your warranty AFAIK
As far as the spike, you have some looking around on your car my friend.
2007 XT
Online   Reply With Quote
