-   -   New to me 2002 Subaru WRX.. advice wanted! (http://www.wrxtuners.com/forums/f51/new-me-2002-subaru-wrx-advice-wanted-33474/)
EPA H8R 01-09-2013 02:12 PM
Hey all, new to the whole turbo'd gas engine.. built a couple old mechanical Cummins so I understand a bit about fuel/air and turbos, but I'm not gonna pretend this car don't stump me because of the computer controlled stuff.
Anyway, I picked up a 2002 Subaru WRX, 165,000 miles with a 5 speed stick shift. Came with a 3 owner carfax, very very clean, and a stack of receipts from all maintenance and work done by the dealer. Car seems in very good condition, I've been driving it about 500 miles and haven't had a problem. Previous owner had dealer replace clutch, turbo, cat, axles, brakes, valve cover gaskets, water pump, radiator hoses and lines, and other stuff about 10k miles ago.
I recently replaced front/rear diff, transmission/transfer case, and engine oils so I know where I stand. No check engine lights, passed inspection easy.
This leads me to the reason I'm posting. Been doing some reading on here, so I figured I'd make an account to ask some questions. The previous owner let his son drive the car for all of a month before I got it, and in those 29 days a Fujita short ram intake and GReddy BOV made their way onto the car.. other than that it is ALL OEM parts. The first thing I had to do was soften the BOV as it wasn't opening, and forcing the air backwards causing turbo flutter. It is set up VTA, I at least have it adjusted where its working properly now. These two upgrades seem to be way out-of-order from what I've read. Is it safe to leave them on? Should I find stock parts and put them back on? This is my DD going to work, school, toting the wife and 3 kids around.. been there done that with go-fasters, I just want a nice reliable fun ride. The only thing I actually want on the car is exhaust, which I just ordered CNT V2 catback after reading some good reviews.. hope its quality.
Sorry for the long post, just getting that background info in and hopefully everything you need to know to get me an answer. Thanks in advance
brfatal 01-09-2013 03:13 PM
Find stock parts. That intake requires tuning in order to have on the ar.
CNT is not made of the material the manufacturer claims it is and they do rust, but considering where you live it won't be as pressing of an issue.
BLAZE2099 01-09-2013 03:20 PM
I'll second on the stock parts. Plus with the mileage, I'd stay away from any mods. Keep it clean and running good... Good luck
EPA H8R 01-09-2013 03:57 PM
Good deal, at least I'm thinking on the right track. Any ideas where I could get the stock setup? I've been Google-ing and on Ebay but I haven't found anything yet, except factory direct that'll run me almost $500 just for the intake stuff. No junk yards anywhere near me either
Is there a better or less aggressive 'aftermarket' setup I can get away with? Or a tuner to help the computer adjust? I've read that the Cobb Accessport V2 can help even the stock setup run better, and correct irregularities
atech34 01-09-2013 06:54 PM
Correct me if I am wrong but I believe that the 02 wrx does not need a tune for the intake nor will it need it for the exhaust?
Just trying to make an easy search easy instead of buying stock parts that may not be needed.
Fidrat 01-09-2013 08:02 PM
Ditch the BOV and the Intake for stock parts. Both are useless noise makers that cause nothing but trouble. Short ram intakes draw HOT air from under the hood.:notgood: Not good. It kind of defeats the purpose of a intercooler.:nono: I really wish these punk-assed kids would stop treating these cars like Hondas.:mad: I really wish I could RAM hot air into my turbo. That sounds like a great idea...NOT :pity:
I'm sure if you poke around on enough forums you will find the parts you need CHEAP! Come on guys..I know someone here has the parts this guy is looking for just lying around collecting dust.
I would go to the previous owners son and hold his head in the toilet until he comes up with the stock parts.
man show 01-09-2013 10:25 PM
My stock bpv is collecting dust ;)
pzr2874 01-10-2013 06:40 AM
Not entirely true Fidrat
COBB's Intake can be fit into their "box", which helps reduce intake heat. The only issue with a Short-Ram
CAI's have their disadvantages as well. Throttle response and water issues.
EPA H8R 01-10-2013 10:17 AM
I picked up a pre-owned but NIB Cobb SF Short Ram Intake and Cobb Intake Air Box for $100, figured that was a good deal! It should work well with the Cobb Accessport I just ordered too. Not really interested in performance gains, but I like that it can read so many things in real-time, pull codes, and go ahead and tune the car to work specifically with that intake.
Might not be stock parts, but it should hopefully work well, yes?
pzr2874 01-10-2013 01:11 PM
It will be fine.
BLAZE2099 01-10-2013 01:51 PM
That's a good intake.
See if man show will part with that bpv for a good price and yer set.
Fidrat 01-10-2013 04:14 PM
Is it any better than a stock airbox with a drop-in K&N and a velocity stack in the fender with the stock snorkus feeding COLD air from the outside the car into the fender?
EPA H8R 01-10-2013 04:31 PM
[quote=BLAZE2099;289508]That's a good intake.
See if man show will part with that bpv for a good price and yer set.[/quote]
Got one from the guy down the road, along with the Cobb intake! Forgot to mention that. Thanks for the advice though
[quote=Fidrat;289513]Is it any better than a stock airbox with a drop-in K&N and a velocity stack in the fender with the stock snorkus feeding COLD air from the outside the car into the fender?[/quote]
Ha no I know it's probably not THAT effective, but I meant better than that weird Fujita thing thats on there now.
Fidrat 01-10-2013 04:58 PM
I'd still stick that kids head in the toilet.:p
EPA H8R 01-10-2013 05:29 PM
If it wasn't a two hour trip up there.. I'd make sure the blue cleaner made it in the toilet too!
