Most practical bolt-on mods to 2008 wrx - Page 2 - Subaru WRX Forum
post #16 of 63 Old 05-08-2012, 08:22 AM
A VF52 turbo by iteself and alcohol injection should not be your very first two mods. Technically, no, you don't need to upgrade your exhaust with the VF52 turbo, but it would be very beneficial to do so. The stock downpipe is arguably the largest power-restrictor on the car. Start with one of those and couple it with some type of Stage 2 tune. After that, start collecting parts for a proper turbo upgrade (fuel pump, injectors, intercooler, intake, etc.) and install those at once and get a protune.
If you haven't seen it yet, this site contains all kinds of good background info on modding: Unabomber's Manifesto - NASIOC
post #17 of 63 Old 05-09-2012, 12:47 AM Thread Starter
sugeina is an unknown
alright, i think i got what i need already... for now, at least.
now, time to look for a good local tuner...
thanks for the help!
sugeina is offline
post #18 of 63 Old 06-26-2012, 01:21 AM Thread Starter
so, i had a tune already after installing an invidia high flow catted downpipe. i also got tein superstreet coilovers, which improved handling quite a lot over stock suspensions.
what's next?
a couple of 2nd hand stock 2011 sti tmic, air pump, and fuel pump are turning up for sale at good prices here where i'm from. are these bolt-ons on an 08wrx?
Last edited by sugeina; 07-02-2012 at 03:54 AM. Reason: found out already that vf48 is not bolt-on
sugeina is offline
post #19 of 63 Old 06-28-2012, 04:16 AM Thread Starter
how much better (in terms of weight and stopping power) are big brake kits over stock brakes?
also, would there be any improvement if i only replace the rotors with larger ones (like this: http://www.speedlab.com.ph/index.php...t/view/233/209 ) but keep the calipers stock?
sugeina is offline
post #20 of 63 Old 07-04-2012, 11:30 AM
BBK's are alot of money and headache. You cant just slap them on and be good to go. Most of them mess with the brake bias and can often times mess up the stopping characteristics of the car. If you want better stopping power, get better pads, rotors, stainless steel brake lines and better fluid. It should handle more than enough for a daily driven car with occasional track duties.
post #21 of 63 Old 07-04-2012, 09:05 PM Thread Starter
hey, thanks for the reply! that confirms it then, no bbk's, but just pads, brake lines, and fluid.
but how about replacing just the rotors to 350mm's (like in the link above)? would it matter if i'm using stock calipers anyway?
sugeina is offline
post #22 of 63 Old 07-05-2012, 05:36 AM
I wouldn't.
Look into the HD Centrics. They have done real well on my car so far.
post #23 of 63 Old 07-05-2012, 04:28 PM
MasterP is an unknown
I have a 2002 Subaru wrx ( bone stock except for an Sti Exhaust) I was wondering if I put a bov on it will it be bad for my car?? Cause that's what I've been told, people are saying I just install a bypass instead? Sorry I'm off topic I just couldn't figure out how to start my own damn post 😡
MasterP is offline
post #24 of 63 Old 07-05-2012, 06:43 PM
Originally Posted by MasterP View Post
I have a 2002 Subaru wrx ( bone stock except for an Sti Exhaust) I was wondering if I put a bov on it will it be bad for my car?? Cause that's what I've been told, people are saying I just install a bypass instead? Sorry I'm off topic I just couldn't figure out how to start my own damn post ��
Well Master P. if thats really who you are...lol
Get the thought of a BOV out of your head NOW!!! bad news man...bad news!!!
Look it up on here and you will see what I'm talking about.
post #25 of 63 Old 07-05-2012, 10:14 PM Thread Starter
read this BOV FAQ Blow Off Valve FAQ: Read if you are thinking of buying one! - NASIOC
and this http://www.wrxtuners.com/forums/f51/bovs-newbs-32071/
but, in summary, "If you are wanting to be 100% sure you arent losing any power from a BOV, and you are running under about 22PSI, you are best off sticking with a stock unit."
sugeina is offline
post #26 of 63 Old 07-05-2012, 10:27 PM Thread Starter
I wouldn't.
Sorry, but, what is HD Centrics?
So, I guess, I'm really better off with just better pads, stock-sized rotors, stainless steel brake lines, better fluid, and a set of Neova ad08's? (excluding all possible weight-reduction mods)
sugeina is offline
post #27 of 63 Old 07-06-2012, 05:56 AM
Centric is a company that bought out DBA I believe. They have several types of rotors for each car.
Discount Brakes - 2008 Subaru Impreza WRX 4 Cyl 2.5L Centric Brakes
post #28 of 63 Old 07-08-2012, 10:50 AM Thread Starter
I wouldn't.
you wouldn't, because... there'd be no benefit from it since your calipers are stock anyway?
sugeina is offline
post #29 of 63 Old 07-08-2012, 01:04 PM
Pretty much.
post #30 of 63 Old 07-08-2012, 01:04 PM
Pretty much.
