My 2002 wrx is totally stock right now and I was wondering what a good first mod could be for not that much money. Also if i get a manual boost controller for my first mod, whats the highest and safest place i can set it at? Thanks for any opinions and suggestions on my begining modifications.
come on kobiashi...you didnt beat me this time? UPPIPE!!!!!! www.turboxs.comwww.gruppe-s.com
i have hte gruppe-s, so does cosmo, kobi has the txs, and they are all good..kobi has it in his sig....read his posts......no mbc, uppipe FIRST!
... SORRY!, I've been out with the Fiancee during the evening (I only beat you from 9-5) =P
-Kobi
The 3 most repeated things I have to say are now in my sig to save typing an extra 5,000 characters a day:
*** DO NOT upgrade your intake until you upgrade your injectors ***
*** DO NOT raise boost until that ugly cat in your uppipe is gone ***
*** DO NOT touch your car with any mod if you like your warranty ***
~~ Need any more help? AIM me OR call [# in profile] ~~~
but its ok...."what can brown do for you?" it brought me a happy box today....hehhe. got to play with my utec finally! with no tunin...just the stage one preprogrammed, i went to 96mph in the quarter! now we wait for the fedex amn...hes bringin some more pieces........then tuning time!
Theoretically you can run as high boost as you want as long as you keep your a/f ratio and egt's in check. If you keep them right, your engine is not running lean enough to hurt anything. But, that's not really the safest way to do things.
What kind of gas you are running also plays a part in how much boost you can run.
Don't raise it above 15.5 in 4th, without an AFR and EGT Gauge (mounted on cyl 3).
-Kobi
hey i just installed a txs turbo back exhaust and got a new boost gauge, in first it tops out at 10psi (i thought 1st and 2nd were limited to 10psi) but in second i hit 14 psi, bout the same in 3rd and 4th, but in 5th on the freeway it peaks at 16 psi then settles around 14-14.5? is that normal without a mbc?
no i don't, at leat not yet, all i did to the car was the exhaust, a k&n drop in air filter, and i replaced the restrictor connector between the wastegate and the boost control? i think thats where it was, maybe thats doing it?
Yeah if you went 3/16's (commonly used) it will. That is where boost is regulated and that is where you are having your problem from. (IF said mods are only thing done to car).
