Lost key and entry fob - Subaru WRX Forum
post #1 of 5 Old 05-18-2007, 05:38 PM Thread Starter
spokeshave is an unknown
Anyone know how much the dealer typically charges for a replacement? It's for an 06 wagon limited.
Thanks.
Tim
spokeshave is offline
post #2 of 5 Old 05-18-2007, 06:03 PM
YAM_R6 is an unknown
look on ebay, there is someone that sells oem replacements for much cheaper. I think the dealer charges about $80 for the keyless entry. All together it would be about $100.
YAM_R6 is offline
post #3 of 5 Old 05-18-2007, 07:39 PM
Cp3aight's Avatar
Cp3aight is more helpful than not
The dealer charges like $80 for the keyless entry thing then an hours worth of labor for installing it. I asked when I got my car cause I wanted 2 sets but wasn't worth $180 for another set.
Cp3aight is offline
post #4 of 5 Old 05-19-2007, 02:38 AM
05WRXRally's Avatar
05WRXRally is more helpful than not
Remember i dont know it the 06's have this but there must be a special magnet in the key or else it will disable the fuel pump and ignition if it does not sense the magnet well at least for my 05
When the green flag drops...the bullshit stops
05WRXRally is offline
post #5 of 5 Old 05-26-2007, 04:34 PM
Dogg777's Avatar
Dogg777 is an unknown
IF you get a keyless entry module off of ebay or some thing else. this is how you program it
REPLACEMENT
KEYLESS TRANSMITTER REGISTRATION
NOTE:
A maximum of four transmitters can be registered for each individual vehicle.
When replacing or adding the keyless transmitter (key), registration is also necessary.
Finish the operation from step 1 through 4 within 45 seconds .
Sit on the driver's seat and close all doors and rear gate.
Open the driver's door.
Close the driver's door.
Turn the ignition switch from ON to LOCK ten times within 15 seconds . NOTE: Do not start the engine at this time.
The horn chirps one time to indicate that the system has entered in the programming mode.
Press any button on the keyless transmitter that you wish to program into the system.
Horn will chirp two times to indicate that the keyless transmitter has been programmed. NOTE: Repeat steps 6 through 9 for an additional keyless transmitter.
10 Remove the ignition key from the ignition switch.
11 The horn will chirp three times to indicate that the system has exited the programming mode.
12 Check the keyless entry system properly operates by operating each keyless transmitter.
Dogg777 is offline
« oil | mods
