I need help with my hybrid build!! - Subaru WRX Forum
post #1 of 9 Old 11-06-2012, 04:57 PM Thread Starter
lancealot is an unknown
I have been researching for about 2 weeks now so I have read Plenty of forums. After alot of looking around I have decided to do the Hybrid build. I think. I dont have much money to work with and I want to get it done by winter and last me. What I think I need is ej257 short block, water pump, oil pump, and gaskets. I have been trying to figure out what gaskets to get and have found no real answer. I am hoping to come out with a price under $2600. I will be running all stock for now. Can I run it without a tune until I have the money to do so?
Thank You
Lance
lancealot is offline
post #2 of 9 Old 11-06-2012, 05:07 PM
Use the EJ257 turbo head gasket, stock ones. No do not run it on the stock tune as this build increase your compression ratio and the fueling and timing will be all wrong.
post #3 of 9 Old 11-06-2012, 05:13 PM Thread Starter
I was also going to do the injector mod. Any idea how much a tune costs?
post #4 of 9 Old 11-06-2012, 05:39 PM
Depends on the shop. I don't know of any tuners near Rumford, Maine, so you'll need to add a good wideband O2 sensor to the cost of an e-tune.
post #5 of 9 Old 11-06-2012, 06:25 PM
Personally just buy new injectors and forget modding them. Well as brfatal said depends on the shop and the method of tune, i.e. Cobb, OS, Hydra, ect. I'm sure I could dig up a map base map for a OS tune that would get you to a tuner.
post #6 of 9 Old 11-06-2012, 06:30 PM Thread Starter
I dont know if I have the money for new Injectors. Where do I Get a cord to do os?
post #7 of 9 Old 11-06-2012, 07:41 PM
Check out this thread to learn more about the OS stuff....
Opensource Read Up..
WitchHunter Performance - Injector Cleaning & Flow Testing Services to have your injectors modded
post #8 of 9 Old 11-06-2012, 08:40 PM
Witchhunter no longer sells injector sets. They will modify yours but there is no guarantee that they will flow similar amounts.
post #9 of 9 Old 11-06-2012, 08:59 PM
They say to send in more than 4 and they will match up the best of the bunch... I am just showing him opinions. I still stand behind upgraded injectors though.
