How do I turn off fact. alarm w/o remote? - Subaru WRX Forum
post #1 of 11 Old 08-25-2007, 04:29 PM Thread Starter
2002 WRX 5spd, missing the factory key fob (remote), everytime i want use the power locks it arms it self then the alarm goes off the next time i use the key to unlock it. So how do i put it into valet mode/ turn is off?
This is the factory subaru security system.
Thanks
02 WRX
doc.. is offline
post #2 of 11 Old 08-25-2007, 05:50 PM
just try to get another remote from the dealership
post #3 of 11 Old 08-25-2007, 08:21 PM Thread Starter
yeah.... i'm kinda looking for option "B"
02 WRX
doc.. is offline
post #4 of 11 Old 08-25-2007, 08:42 PM
W0R2X's Avatar
Images: 11
Send a message via AIM to W0R2X
i thought that the factory unit had a little button on the back of it, where the led is, if i hold mine for three seconds it goes into valet mode
W0R2X is offline
post #5 of 11 Old 08-25-2007, 08:59 PM
W0R2X's Avatar
Images: 11
oh wait, nm, i forgot that i have the KARR system. subaru doesnt have the led. my bad
W0R2X is offline
post #6 of 11 Old 08-25-2007, 09:00 PM
Send a message via AIM to Black Night
just disable the brain of the security system...like someone said just go to the dealership and get a key fob, or look on ebay, they can all be programmed...i have an 05 and i think mine was under my driver dashboard....oh, and the fobs are very inexpensive, spend the extra 10-15 bucks
Black Night is offline
post #7 of 11 Old 08-27-2007, 07:48 PM Thread Starter
yeah, i priced them out at $130...
02 WRX
doc.. is offline
post #8 of 11 Old 08-27-2007, 09:40 PM
wrx3r's Avatar
i bought my shipped off ebay for 14.50....
bigger and better than ever
wrx3r is offline
post #9 of 11 Old 08-28-2007, 05:34 AM
To turn off the system you have to turn the car to on (not start) and back to off really fast like 5x's.To disable the system you have to remove part of the center consol.Its a black box located by the emergency brake.Just unplug it.
dumdum is offline
post #10 of 11 Old 08-30-2007, 11:32 AM
I also believe that this is the easist way w/o the FOB.
post #11 of 11 Old 09-04-2007, 11:22 AM
Dogg777's Avatar
Security System
FEATURES
The security system protects the vehicle from a theft action (unauthorized entry into the vehicle).
Upon detection of such an action, it gives audible and visible alarms by causing the horn to sound and the parking lights to flash. It also immobilizes the vehicle by disabling the starter circuit.
Unauthorized entry is monitored through the switches on the doors, rear gate and trunk lid. If one of the switches is turned ON, the system interprets it as an attempt of unauthorized entry and gives alarms while disabling the starter circuit.
Unauthorized entry is also monitored by the impact sensor. The system operates in the same manner as mentioned above whenever the sensor senses an abnormal impact on the vehicle.
1. ALARMS
When activated, the security system causes the parking lights to flash and the horn to sound intermittently. In addition, the security indicator light on combination meter flashes fast and the starter motor circuit is disabled.
The alarms automatically turn OFF after 30 seconds . However, they will be reactivated if the vehicle is tampered with again.
The alarms are activated when a door, rear gate or trunk lid is opened without using the keyless entry transmitter. (When the system is armed, the alarms will be triggered even if a door is opened by releasing the inside door handle or the trunk lid is opened by operating the trunk lid release lever.)
They are also activated when an impact on vehicle body is sensed.
2. HOW TO ARM THE SYSTEM
Remove the key from the ignition switch.
Make sure that the trunk lid is closed.
Close all the windows. Close and lock all the doors and rear gate.
Push the transmitter's LOCK button.
The horn will chirp once and the parking lights will flash once. NOTE : The system can be armed even if the windows are open.
Confirm that the security indicator light blinks slowly (once every two seconds ). If any of the doors, rear gate or trunk lid is not properly closed, the system warns the driver of this by causing the horn to chirp three times, the parking lights to flash three times, and the security indicator to flash rapidly. When the door, rear gate or trunk lid is closed, it will be automatically locked and the security system starts working. The indicator light blinks every two seconds when the system is armed and continues to blink until the system is disarmed.
3. HOW TO DISARM THE SYSTEM
Push keyless entry transmitter's UNLOCK button.
The horn will chirp twice and the parking lights flash twice.
The security indicator light turns OFF.
The interior light will illuminate for 30 seconds and then turns OFF (However, if a system arming procedure is performed during this period, the interior light will turn OFF .)
4. HOW TO STOP ALARMS
Push the transmitter's UNLOCK button or turn the ignition switch from "LOCK" to "ON" repeatedly three times at an interval shorter than five seconds .
Dogg777 is offline
