Old 12-27-2007, 06:48 PM   #1 (permalink)
Car: 04 WRX
Reputation: shamrock is an unknown
How to clean MAF. HELP FAST................
I need to know how to clean the MAF. I have the cleaner, but where is the MAF located.
I think its on the (plastic intake tube)
Anyone have a pic of it.
_Ryan_
2004 Wrb "BUGEYE"
Old 12-27-2007, 10:10 PM   #2 (permalink)
2006WRXTR's Avatar
Club Region: Gulf Coast
Reputation: 2006WRXTR is an unknown
Send a message via AIM to 2006WRXTR Send a message via Yahoo to 2006WRXTR
It is easy. On my intake, the MAF on the intake tube; the black square held on by two bolts between the two clamps. The MAF in the picture below is stock, so yours will look the same, or similar. Just unscrew the two bolts holding it on and using a q-tip and rubbing alcohol, gently rub the 'dew drop' looking sensor portion. It will most likely look dull/dusty before you clean it. But once you clean it, it will look shiny again.
Rich
Latest: Meth Injection, StreetTuner
Old 12-28-2007, 06:55 PM   #3 (permalink)
thewr3tched's Avatar
Car: 05 WRX
Club Region: Southeast
Reputation: thewr3tched is an unknown
Send a message via MSN to thewr3tched
i believe the MAF sensor is actually up inside the unit. the "dewdrop" looking sensor is the air intake temp sensor from what i've been told. once you have it off, you can shine a light inside and you'll see 2 more sensors up inside. you may be able to clean it with a q-tip, but i've always been told to never touch the maf sensor with anything. just spray it down good with the cleaner and let it dry off.
it's an expensive piece, so handle with care!
Old 12-28-2007, 08:02 PM   #4 (permalink)
Novtec1's Avatar
Reputation: Novtec1 is more helpful than not
go to auto zone, pepboys, advanced auto
buy MAF cleaner (comes in a spray can)
take maf off car
spray down
let dry
re-install maf
enjoy!!!!
07 STI
03 subaru WRX <Wifes car
00 2.5 RS
Old 12-29-2007, 07:40 AM   #5 (permalink)
2006WRXTR's Avatar
Yes. It is. I stand corrected. Thanks! Spray that part only... try not to spray it 'directly' as it it could damage that portion.
Rich
