How can you tell if your motor is done for?? - Subaru WRX Forum
 4Likes
  • 1 Post By BLAZE2099
  • 1 Post By LW_Black4
  • 1 Post By Cosmo_kraemer
post #1 of 10 Old 05-03-2014, 03:16 PM Thread Starter
Cosmo_kraemer's Avatar
Cosmo_kraemer is an unknown
As it states I'm trying to find out how you can tell if my ej205 is shot or not. I have noticed a little drop in lower end power mainly when I take off. I wa thinking it was my turbo as it spools funny at higher speeds and rpm's. Like it acts like it is governed it hits .10 on my lamco gauge and drops a few ticks and builds back up. But back to the motor, so like I said when I go to take off It acts like it has no real power so sometimes. But at higher speeds it picks up good. Any help testing things out would be great.
Cosmo_kraemer is offline
post #2 of 10 Old 05-03-2014, 03:49 PM
thekamikaze kid's Avatar
Try doing a data log
thekamikaze kid is offline
post #3 of 10 Old 05-03-2014, 04:16 PM Thread Starter
dont have an AP yet. and dont want to buy one if my car will be down for a while as i deploy in Aug.any other ways?i can say i have a slight tick when you let off the gas on what i would want ot say is cylinder 3.(passenger closest to the firewall.) is that normal. i have heard it on a few different subies before.its not like the ticking you hear in the bent rod/spun bearing video's.
post #4 of 10 Old 05-03-2014, 05:37 PM
All subies have a slight knock, that's normal.
Is there white foam in your oil?
Is there oil in your coolant?
Cosmo_kraemer likes this.
post #5 of 10 Old 05-03-2014, 06:16 PM
LW_Black4's Avatar
Compression or leakdown test will tell you the health of your engine.
There's a procedure in the Service Manual with test specs, but it's better to have a competent shop do it for you for the 1st time. They'll be able to interpret the results and suggest remedies if issues are identified.
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #6 of 10 Old 05-03-2014, 06:42 PM Thread Starter
ok i thought the knock on 3 was common. and no coolant in oil just did oil change Thursday. but it does look like a white film on the top of my overfill tank. but my hose that runs to the tank has alot of white crust in it, so i was thinking the film was from that but that just started.but no oil or black shit in the tank.....i do know i have a valve cover leak could i be losing compression from that maybe? and it looks like i will have to find a manual online as mine was not with the car when i got it.but it looks like i will have to find a shop and see how much a compression test will cost. i have been thinking of doing that here soon, looks like it will be next month.
post #7 of 10 Old 05-04-2014, 12:46 PM
Subarufan123 is an unknown
So the ticking from our motors is normal? My Bugeye has been ticking ever since I got her at 108,xxx miles. I don't really ever feel any power loss most of the time, and I'm currently Stage 1 with the Acessport. The only time I feel some power loss is when it's really hot outside. My clutch gets kind of soft as well. I installed a Kartboy Pitch Mount not to long ago and I can really hear the ticking, etc. through the fire wall now. Sounds like my car wants to die.
Subarufan123 is offline
post #8 of 10 Old 05-04-2014, 03:48 PM Thread Starter
thanks for the input. and the ticking goes away a little after she is warmed up so i think the piston slap is just getting a bit louder maybe.but i talked to my old man who has been a mechanic for almost 20 plus years now. now hes not s subie mech but i asked his input on the issues and said to get my injectors looked at maybe one has a weak spray so i will be looking into that also once i get the compression test.
post #9 of 10 Old 05-04-2014, 04:23 PM
Yea, a little tap is normal.
I've had an 02, 04 and 11. All have had it.
post #10 of 10 Old 05-04-2014, 04:52 PM Thread Starter
ok well i feel alot better now i about cried when i heard it but once i get home next year i will be rebuilding the short block. but for now i will just keep an eye on the car.
BLAZE2099 likes this.
