Old 04-16-2008, 04:23 AM   #1 (permalink)
Reputation: tclolo is an unknown
horrible gas mileage
i just got my 06 wrx wagon, but i realize this car get horrible gas mileage, in the user manual says the car has a 15.9 gallon tank, but every time i fill up the tank i only get a little bit over 200 miles.i shift around 2.5k rpm just like what it says in the manual and i usually put in neutral and coast when i hit a stop sign or red light. well, I'm not so good at stick shift car yet,but i think right i shift pretty smooth,are there anything wrong with the way i drive or something is wrong with my car?
ps. i just got a K&N typhoon intake, i hope it'll give me better gas mileage.
sorry for the poor English, English is not my first language
Last edited by mosc : 04-29-2008 at 03:34 PM. Reason: Your spelling his so friggin horibal that I can't stay nutural anymore and must fix your English (which needs a capital).
Old 04-16-2008, 05:22 AM   #2 (permalink)
Jave's Avatar
Car: 04 WRX
Timeslip: 9.999 @ 106.14
Trader Rating: (3)
Reputation: Jave is more helpful than not
you have yet to post what you gas mileage is... divide your miles by your gallons and see what you are getting.
▼SùbiΣ Mäƒiä▼
Old 04-16-2008, 07:11 AM   #3 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
maybe shift a little later so the car isn't so bogged down and the engine wont have to work as hard, have you tried a new fuel filter or maybe different plugs something easy like that? judging on your numbers you are only getting like 12.5 MPG you should be at least 20 or so.
Old 04-16-2008, 11:27 AM   #4 (permalink)
Reputation: NukeFusion is an unknown
Just because you have a 15.9 gallon tank doesn't mean that you are using 15.9 gallons of fuel between fill-ups. What what the gas pump says, and go off of that. When i full up for a full tank it is usually about 12.9 gallons. Hence the 3 gallons of safety tank fuel that you only use if you run it completely dry.
Last edited by mosc : 04-29-2008 at 03:17 PM. Reason: completly isn't completely wrong... I guess
Old 04-16-2008, 11:42 AM   #5 (permalink)
Reputation: dremers is an unknown
yeah that still seems to be a little low and you should also remember that when the yellow gas light comes on that you still have about 3 gallons worth of fuel in your tank.
Old 04-16-2008, 12:02 PM   #6 (permalink)
Jave's Avatar
Car: 04 WRX
Trader Rating: (3)
let me add a little more to this.
When you fill your car divide the miles by the gallons of gas bought like stated above.
▼SùbiΣ Mäƒiä▼
Old 04-16-2008, 01:19 PM   #7 (permalink)
VD5505's Avatar
just fill your tank till it clicks then stop, get in your car set the trip meter till it says 0 then drive till you have like a 1/4 tank of gas then fill it again till it clicks, then go look at how many miles you have drove then divide that by how many gallons you just put in
Old 04-16-2008, 10:58 PM   #8 (permalink)
Reputation: baller_v24 is a helpful contributing member
that is pretty bad, i was in the same boat, and I'm like wtf!!!! i realized i had been neglecting my tires and was a little low on air. filled it up to factory specs and gained 2 mpg's.
check your tire pressure people every time u fill up.
Old 04-17-2008, 07:29 AM   #9 (permalink)
b7g
b7g's Avatar
Reputation: b7g is an unknown
Originally Posted by baller_v24 View Post
that is pretty bad, i was in the same boat, and im like wtf!!!! i realized i had been neglecting my tires and was a little low on air. filled it up to factory specs and gained 2 mpg's.
+1000
drive = freedom
Old 04-17-2008, 12:37 PM   #10 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is an unknown
Have you cleaned your injectors also.... I have noticed that the gas in certain areas is crappier than others. BG44K and Seafoam
2007 WRX
Last edited by mosc : 04-29-2008 at 03:20 PM. Reason: yur going to have to use english here from now on...
Old 04-17-2008, 03:58 PM   #11 (permalink)
BC_Girl's Avatar
Car: 04 WRX
Reputation: BC_Girl is an unknown
You are putting in premium right? I got cheap and started running mid-grade because I thought..... well, it's better than regular and cheaper than premium....WRONG! It's worth it to spend the extra on premium....my 04 runs great on Shell V-Power and I get better gas mileage so in the long run it's really not that much more expensive.
Boys will be boys, but girls will be fast !
Old 04-26-2008, 07:28 AM   #12 (permalink)
BC, you can seriously screw up your ride putting lower grade in there.
HOW DARE YOU !!!
2007 WRX
Last edited by mosc : 04-29-2008 at 03:20 PM. Reason: yur really getting on my nerves
Old 04-26-2008, 02:03 PM   #13 (permalink)
use recommended fuel grade, which is premium...says on the inside of the gas door and in owner's manual.
Old 04-26-2008, 03:35 PM   #14 (permalink)
VD5505's Avatar
what are some of your guys octane ratings here in Iowa we have 92
Old 04-26-2008, 05:19 PM   #15 (permalink)
Reputation: man show is a helpful contributing member
Here in Maryland I like to use Shell V-Power 93 Octane
07 WRX - Cobb AP Stage 2
