All,
I need some help deciding what direction I should take my 09 WRX, so I was wondering which options (option 1 or option 2) makes more sense or which would you go with and why? Also, if you had to change this build, which part of it would you change and why? I currently have the parts below installed, which equates to 371whp & 377wtq on 93 octane on 21psi.
All help and opinions are welcomed!
CURRENTLY INSTALLED PERFORMANCE PARTS
Cobb AP
IAG up-pipe
IAG UEL headers
IAG TGV deletes
Tial 38mm EWG
1000cc ID injectors
DeatschWerks DW65c fuel pump
Invidia Q300 exhausted
Invidia catless DP
Blouch Dom 1.5xt-r 8cm
AEM CAI
Perrin turbo inlet
FMS FMIC
Grimspeed EBCS
Grimspeed lightweight pulley
Go Fast Bitz BOV
NGK spark plugs
Exedy lightweight flywheel
Act performance street spring clutch
*OPTION 1* PURPOSED PERFORMANCE PARTS
Kstech Mega MAF 83 or 73mm
Killer Bee oil pick-up
Killer Bee oil baffle
Manley pistons
Manley connecting rods
IAG crank shaft
ACL rod bearing
ACL main bearing
APR head studs
4 bar MAP sensor
*OPTION 2* PURPOSED PERFORMANCE PARTS
All of option plus
BC titanium valve spring and retainers
BC intake valves
BC exhaust valves
BC 272 cams
Grimspeed AOS
Cobb AP
IAG up-pipe
IAG UEL headers
IAG TGV deletes
Tial 38mm EWG
1000cc ID injectors
Invidia catless DP
AEM CAI
Perrin turbo inlet
FMS FMIC
Grimspeed EBCS
Go Fast Bitz BOV
NGK spark plugs
Manley pistons
IAG crank shaft
ACL rod bearing
ACL main bearing
APR head studs
4 bar MAP sensor
All of option plus
BC intake valves
BC exhaust valves
BC 272 cams
Grimspeed AOS
