help with bov? - Page 2 - Subaru WRX Forum
 23Likes
post #16 of 23 Old 03-19-2014, 02:13 PM
arcticscythe's Avatar
Originally Posted by whitepearl View Post
thanks for the help. Is cobb the best intake? and whats best ecu?
Before the sh*t-storm on the horizon there is no "BEST Intake" each product has its merits. assuming you are planning on a stage 1 OTS tune the Cobb SF with box is very easy to install and because most people do stage 1 with an accessport the tune procedure is 1/10 on the difficulty scale. With the box you also get the benifit fo using the stock snorkel so your air is "in theory" cooler than engine bay air.
the Cobb SF intake will NOT provide the fastest, coldest or the most dense air but the installation is extremely easy, the tune with an accessport takes 5 minutes and it is louder than your stock intake. Many drivers report being able to hear more from their stock BOV with the Cobb SF so you will get a bit of that "whoost" that some folks love so much. Finally they are very well used across the community so there is support if you have trouble with it.
**TLDR the Cobb SF intake is GOOD, but nothing is the BEST for everyone**
- Jason
arcticscythe is offline
post #17 of 23 Old 03-19-2014, 10:01 PM
bluestreak is an unknown
Blow off valves are generally frowned upon, but one with an adjustable spring is better than one without. I have an APS dual vent so that some MAF'd air is recirculated. It only backfires under wide open throttle.
I thought it would spool faster between shifts but I noticed absolutely nill performance difference However, I love the sound and the flames FTW!
I feel safer getting a tune after installing it even though I've heard tuning doesn't affect it much. I don't think I would recommend one without a tune.
bluestreak is offline
post #18 of 23 Old 04-20-2014, 01:11 PM
travism is an unknown
Hey guys. I've got an 03 wrx with a front mount intercooler. It has a greddy bov not sure what model. It leaks with anything over 10psi though. I want a new bov. Or tips to try with the one I've got.
travism is offline
post #19 of 23 Old 04-21-2014, 09:20 AM
That doesn't sounds too healthy. See if it has a screw or something you can tighten up. If not, get a bov that is partially recirculating & adjustable so it doesn't leak. You should easily be able to find details on how to adjust a bov. Good luck!
post #20 of 23 Old 04-21-2014, 09:24 AM
lfuller1988's Avatar
lfuller1988 is an unknown
have someone who knows what they are doing install and tune and you will be fine
lfuller1988 is offline
post #21 of 23 Old 04-21-2014, 04:27 PM
Swap it for a Cobb XLE or a Go Fast Bits 50/50.
You may need a full vent depending on your IC pipe though.
In that case I recommend a TurboSmart V Port
post #22 of 23 Old 04-23-2014, 12:44 PM
+1 Cobb XLE
I have one set on full recirc and it makes plenty of fun wooshing sounds and it regularly holds 25 psi.
turmic, BLAZE2099 and arewmors like this.
post #23 of 23 Old 04-23-2014, 06:31 PM
Originally Posted by man show View Post
+1 Cobb XLE
I even ran mine 50/50 with no issues. It's a sound piece
man show and arewmors like this.
