Old 05-23-2004, 01:57 PM   #1 (permalink)
Reputation: 4wheeler is an unknown
Front brake noise
When I apply the brakes I get a slight clunking sound. I check the calipers and they seem to have a little movement is this normal.
Old 05-23-2004, 07:26 PM   #2 (permalink)
AZ-Scoob's Avatar
Reputation: AZ-Scoob is an unknown
Send a message via MSN to AZ-Scoob
a little movement is normal, the caliper is mounted to sliders to allow for pad wear. check for pad movement both up and down and front to back. there may be a problem with the shims or clips(worn or missing. I always recommend replacing them with every brake service. what you may be hearing is the pads knocking around when the brakes are applied. there could also be a problem with the dust boot on the caliper piston, might be stuck to the piston and is pulling the piston back after the brakes are applied, can cause a clunk on application but usually also has a mushy pedal feel as well.
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
Old 05-23-2004, 08:12 PM   #3 (permalink)
Thumbs up Front brakes
Hey thanks for the info I'm going to pull the calipers off and check the pads and the shims.
