fog lights conversion - Subaru WRX Forum
 19Likes
post #1 of 29 Old 03-29-2014, 09:09 PM Thread Starter
VANY's Avatar
VANY is an unknown
Question fog lights conversion
I got one busted fog lights and thought of doing HID conversion, 35W 5000K..Saw some negative feedbacks having HID's on your fog lights on some other forums and I would be open for any feedbacks from here. But, I will be still doing the conversion no matter what because i got the kit already.
Also any suggestions, will be greatly appreciated as per with installation is concern. I heard that the fog lights are more complicated than the headlights since that you have to do it underneath and customization is needed for the dust cap.
Any thoughts?
VANY is offline
post #2 of 29 Old 03-30-2014, 02:28 AM
HIDs completely undo the entire purpose of foglights. They simply emit too might light for use in fog and snow and will hurt your vision rather than help it. Not to mention that HIDs in fogs will be glare city.
You're not supposed to use your foglights in clear weather anways, so there is no point to going brighter at all. This is explained here:
04/05 wrx extra lighting?
post #3 of 29 Old 03-30-2014, 04:55 AM
Fidrat's Avatar
HIDs in the fogs? Not a very bright idea.
Fidrat is offline
post #4 of 29 Old 03-31-2014, 02:04 AM
arcticscythe's Avatar
VANY
Please dont install HIDs in any housing designed for halogens, Its not safe for other drivers and in the case of fog lights it would be counter productive.
The best headlights are the ones that are just bright enough that they allow your eyes to adjust and see the road. Brighter isnt better, especially for fog lamps. Keep them halogen and keep them off until it gets foggy.
- Jason
arcticscythe is offline
post #5 of 29 Old 03-31-2014, 04:28 PM Thread Starter
VANY's Avatar
VANY is an unknown
I hear everyones concern here and i am glad that you guys are throwing me all these opinions. I already got the kit and returning will be more work and pain in the butt. Ive installed HIDs on my fogs from previous car and didnt seem to bother anyone since i pointed it towards the road and i will make sure ill do the same way.
Thanks evryone!
VANY is offline
post #6 of 29 Old 03-31-2014, 10:20 PM
*sigh* Please don't be in NoVA.
post #7 of 29 Old 04-01-2014, 08:02 PM Thread Starter
VANY's Avatar
VANY is an unknown
Huh?
VANY is offline
post #8 of 29 Old 04-01-2014, 09:32 PM
NoVA. Northern VA. I don't want to deal with that glare.
DB_VW likes this.
post #9 of 29 Old 04-02-2014, 05:31 AM
By installing these fully knowing what you're doing. I'm sorry, but you're an a-hole.
Ps. Good luck in the fog as those won't do a damn thing for cutting through it. Just makes it worse.
Fidrat, arewmors, DB_VW and 1 others like this.
post #10 of 29 Old 04-02-2014, 05:51 AM
Riceburner is an unknown
Man Vany, you're so cool putting hids in your fogs!
BLAZE2099 likes this.
Riceburner is offline
post #11 of 29 Old 04-02-2014, 11:55 AM
Thanks evryone!
Word to the wise, HID "Kits" that run on halogen sockets are typically made in china to less than exacting standards, they often throw a huge amount of non-visible radiation that can lead to melted housings and de-lamination of chromium coatings. the difference between Chinese made HID lamps and real HID lamps is huge, real HIDs only come on high voltage mounts and throw little to no infrared and ultraviolet radiation. If you have a set of drop in HIDs then they are not "good HIDs", weather you pay $29.99 or $229.99 you get the same made in china, wrapped in thermal plastic garbage.
I know better than to tell someone to throw away money but please don't damage your fog lamp assemblies with drop in HIDs, aside from blinding people and hurting your distance/fog vision they will eventually damage the coatings on the inside of your fog lamps.
If your going to do it anyway then please check your fog lamp housings whenever you wash the car and please only run them when you are driving ofroad or on private roads where the chance of blinding other drivers is minimal.
- Jason
post #12 of 29 Old 04-02-2014, 08:16 PM
He's not going to listen Jason, probably won't even reply again.
post #13 of 29 Old 04-05-2014, 09:45 PM Thread Starter
VANY's Avatar
VANY is an unknown
Been busy the past few days and took me awhile to reply. Just to let everyone know that I didn't do the conversion. I took down my bumper and saw that there's a dust cap cover and I don't wanna alter that to fit the HID cables. I running with the stock bulbs right now.
VANY is offline
post #14 of 29 Old 04-05-2014, 09:51 PM Thread Starter
VANY's Avatar
VANY is an unknown
If I wasn't able to reply right away, it doesn't mean that I'm not listening. I have other things to attend to aside from my car like a job and 2 teenagers!
VANY is offline
post #15 of 29 Old 04-05-2014, 09:54 PM Thread Starter
VANY's Avatar
VANY is an unknown
Thanks for the info, appreciate it!
VANY is offline
