Engine oil - Subaru WRX Forum
post #1 of 7 Old 03-26-2013, 09:34 AM Thread Starter
NeverSummer's Avatar
Engine oil
Just seeing what people options are on engine oil? I hear alot about using rotella t6 5w-40. I'd like to hear people's opinions....pros/cons on diff brand oils. Thank guys!
Sent from AutoGuide.com App
NeverSummer is offline
post #2 of 7 Old 03-26-2013, 10:34 AM
I use Motul 5W-40 because my engine was rebuilt with forged internals and it has slightly looser clearances than stock so the thicker oil was recommended by my tuner to help lubricate everything properly. I've been buying it in bulk (four 5L containers at a time) from Amazon.com.
post #3 of 7 Old 03-26-2013, 10:46 AM Thread Starter
Engine oil
I'm considering using 5w-40 rotella t6. I will be at stage 2 when I make the switch. It can't hurt from I read
post #4 of 7 Old 03-26-2013, 10:51 AM
As long as you don't run E85, T6 should perform very well.
post #5 of 7 Old 03-26-2013, 10:57 AM Thread Starter
Engine oil
If I was to do injectors, fuel pump, and 3 port bcs, what's a better oil?
post #6 of 7 Old 03-26-2013, 01:49 PM
Fidrat's Avatar
This is every thing I know about oil. ???synthetic oil??? - merged
Although,I've been told that some Wall Mart stores now have Royal purple oil. Also,that post of mine is old so my list may not be complete.
Fidrat is offline
post #7 of 7 Old 03-26-2013, 04:51 PM Thread Starter
Thanks
