-   -   Ej20g Swap (http://www.wrxtuners.com/forums/f51/ej20g-swap-33388/)
MidnightPrince 12-19-2012 05:02 AM
Ej20g Swap
I have a 2002 wrx that spun a bearing and I'm looking to swap a 97 ej20g. Is it a direct drop in? Can I use my stock wiring harness and ecu? Or is it better to just get a ej257 short block?
psinuse 12-19-2012 04:08 PM
I'd recommend using just the shortblock. That will save you alot of headaches.
brfatal 12-19-2012 04:29 PM
EJ20G is not plug and play nor a particularly good investment. If budget is an issue stick with another EJ205 block. If you have money to spend, get the EJ25 block and get your heads machined out to match it.
MidnightPrince 12-22-2012 11:48 PM
What I'm looking at now is the hybrid swap ej205 heads with ej257 short block
Is this a direct swap (mounts, tranny, ecu, etc.)?
What gains am I looking at?
Do I need to do anything to the heads (port, bore, etc.)?
What's max Boost that I can run on This?
