» Sponsor Links
»Garage Storage and Cabinets
Old 01-23-2008, 03:36 AM   #1 (permalink)
wolfracing's Avatar
Reputation: wolfracing is an unknown
Send a message via Yahoo to wolfracing
EJ20 vs. EJ25
Can any one tell me what can be interchanged with EJ20 and EJ25 I can not find this info any where?
Brandon
2002 subaru wrx stock....not for long
Old 01-24-2008, 09:13 AM   #2 (permalink)
Reputation: blacktalon9 is an unknown
Not much is the same, but some things can be used. The heads are different. STI heads have different cams and AVCS. EJ20 heads can be bolted on a EJ25 or vice versa. The pistons are obviously different. The 25's are a wider diameter. I believe the wrist pins are the same. The STI ej25 has a vf39 turbo... the WRX has a TDO4.... the STI turbo can be bolted on the wrx for more power. The STI up pipe will directly bolt into the EJ20. The WRX has a cataletic converter in the up pipe which is a bad thing... the cranks are different and you must change your rods to use then in one block or the other... what else do you wanna know?
Old 01-24-2008, 09:17 AM   #3 (permalink)
The intercooler on the STI is larger but will work on the WRX. The US STI injectors will not work on a WRX. They are side feed. The japanese STI's have 2.0 engines in them and have injectors that will work in the WRX. They are called STI "pinks."
Old 01-24-2008, 01:13 PM   #4 (permalink)
the STi intercooler has a slightly different angle than the 02-05 WRX's. It fits, you just have to be aware of that and adjust things accordingly. I think the 06-07 use the same position of the IC on STI and WRX...
Engineers can't spell, sorry!
Old 01-24-2008, 08:02 PM   #5 (permalink)
b7g
b7g's Avatar
Reputation: b7g is an unknown
Do you mean an ej 205 and ej 255, wrx motors? If so, then basically nothing but displacement. However I think an 04/05 Forester motor is the same as ej257 sti's.
But if you thinking of hybridizing 205 and 255, i am not sure on which head gasket to use...
maybe someone does...
drive = freedom
Old 01-24-2008, 11:51 PM   #6 (permalink)
Reputation: baller_v24 is a helpful contributing member
i think the throttle body too, not sure though. i dont know about the intake manifold.
Online
Old 01-25-2008, 12:47 AM   #7 (permalink)
wolfracing's Avatar
I am look at like oil pan pick up and pump
Brandon
