Dyno/tuning??? - Page 2 - Subaru WRX Forum
post #16 of 21 Old 12-19-2011, 05:42 PM
Roman777 is an unknown
Originally Posted by man show View Post
^ Yep. If I remember right from looking at the screen, it ended up being 238 whp, 308 tq. I'll post a more detailed thread when they email me the dyno graph. Cost was $500 for the tune and another $100 for pre-dyno inspection (changed oil, compression check, boost/exhaust leak checks, etc.). The car feels so smooth now - it was worth every penny
stock turbo and tranny right?
Roman777 is offline
post #17 of 21 Old 12-19-2011, 07:15 PM
I thought you were running more than that before you blew your trans????
Nope, same parts (minus the ebcs and fuel pump). You might be thinking of the numbers Cobb claims for their generic Stage 2 map = 285 hp and 340 ft-lb tq. Those numbers are estimated at the crank, not actually measured at the wheels. Subtract about 20% for drivetrain losses to figure out how much that would be at the wheels and it becomes 228 hp and 272 ft-lb tq. Assuming that (1) those numbers are actually accurate and (2) that's what my car actually had, I still gained a little of both after the pro tune. I'm not terribly concerned with numbers at this point anyway since the car is my daily driver. My intention was to safely maximize power given my extra bolt-on parts beyond "Stage 2" since I'm still not quite ready to upgrade the turbo.
John was only running at STG2 AP OTS map. He had more bolt ons, but never was tuned for them if I recall correctly. Not too shabby a number tho. I would be happy with that (for a month at best, lol).
Correct. I'm definitely happy - it's so much smoother than it was. It's not a major jump in power, but I can feel it.
Stock TD04 turbo and aftermarket Albins helical 1-5 gears.
post #18 of 21 Old 12-19-2011, 07:16 PM
John (man show) has upgraded 5 spd gears. Because his gears already broke. But, he does have a stock turbo.
Foiled, john beat me to the post. Lol
post #19 of 21 Old 12-19-2011, 07:53 PM
Just glad to hear you are happy John. Thats the big thing there. I beat its got a nice kick and makes for a little bit of a small when you jab the go pedal.
post #20 of 21 Old 12-01-2013, 11:23 PM
lfuller1988's Avatar
lfuller1988 is an unknown
Clutch on the Dyno
I am going to upgrade my turbo here in the next month. I have the supporting mods. I was thinking about upgrading my clutch at the same time. I know there is a clutch breakin period where you are not supposed to over heat the clutch. If I install the clutch and do a dyno would that overheat the clutch?
lfuller1988 is offline
post #21 of 21 Old 12-02-2013, 12:10 AM
You'll be fine.
