DSM powered WRX?? - Subaru WRX Forum
post #1 of 22 Old 06-10-2009, 02:02 PM Thread Starter
Kyole's Avatar
Kyole is an unknown
DSM powered WRX??
so... i bought an 02 wrx with 72,xxx miles on it and it needed a bearing in the tranny. i pulled the tranny out to fix the bearing and after that i was just inspecting the rear of my engine, the turbo, and everything i could see, well, i saw a mitsubshi logo on my turbo. what could it be? a gsx turbo?? cant get pics but there are no id numbers or anything on it..
Kyole is offline
post #2 of 22 Old 06-10-2009, 04:22 PM
The turbos on the wrx are made by mitsubishi. I believe the the td-04 is the same turbo that's in the vr4.
Someone feel free to correct me if I'm wrong.
post #3 of 22 Old 06-10-2009, 05:12 PM
yep we have mitsu turbos...and the VR-4 does use a TD04 but im not sure if it is the same one as there are a lot of different models
post #4 of 22 Old 06-10-2009, 09:22 PM
jed344's Avatar
jed344 is an unknown
tdo4-13t if i remeber? but yes dont be afraid ## stock turbo ###### does say that lol
jed344 is offline
post #5 of 22 Old 06-10-2009, 10:02 PM
yup we run the 13T in the US...i just wasn't sure about the VR-4
post #6 of 22 Old 06-11-2009, 01:38 PM Thread Starter
Kyole's Avatar
Kyole is an unknown
haha ok. thanks for claring that up for me guys. i was told it was an unmolested stocker but then i saw this and thought-!Cry! but now its good to know its stock. kinda bittersweet though...
Kyole is offline
post #7 of 22 Old 06-11-2009, 03:24 PM
Why? Subaru doesn't make a lot of the parts in your car, including turbos. Mitsu turbos, especially the smaller ones, are very nice. Later years switched to inferior IHI turbos. Consider yourself lucky!
post #8 of 22 Old 06-12-2009, 08:32 AM Thread Starter
Kyole's Avatar
Kyole is an unknown
A buddy of mine used to have a GSX and that thing flew. he had it tuned at something rediculous. i want to say he was pushing like 22lbs? i think thats what he said.. ive read around and i think i gathered that the stock ej205 internals can handle around 19psi at the max??
Kyole is offline
post #9 of 22 Old 06-12-2009, 08:40 AM
yeah but the GSX's come stock with 16G's...and the 205 can handle a little more than that...mine held 21lbs on a VF34 for 4 years till the rod bearings gave out...and that was after I pushed it to its limit almost everyday
post #10 of 22 Old 06-12-2009, 09:09 AM Thread Starter
Kyole's Avatar
Kyole is an unknown
so, theoretically, i could get a 16g from a gsx and swap the turbos? but then again, this is a noob talkin.
Kyole is offline
post #11 of 22 Old 06-12-2009, 09:39 AM
No, the layout is different. "16G" just means a rough sizing of the compressor (although there are dozens of 16G compressors out there). The actual turbo in question will not be a "bolt-on" unless it shares the same layouts. Turbos come in multiple layouts with the same name.
Could you strap a similar sized turbo to the one on the GSX? Yes. You could strap a lot of things on there.
post #12 of 22 Old 06-12-2009, 11:19 AM Thread Starter
Kyole's Avatar
Kyole is an unknown
ahh. i see. yeah im new to these small displacement turbo engines... but im loving every second of my wrx
Kyole is offline
post #13 of 22 Old 06-12-2009, 11:53 AM
jed344's Avatar
if the GSX had stock turbo and ## are refering to awd eclipse then no it will not have a 16g it would have had a T-25 i think
jed344 is offline
post #14 of 22 Old 06-12-2009, 12:04 PM
sorry you are completely correct...I got my evo confused with the GSX...both have basically the same drivetrain...GSX's are the T-25
post #15 of 22 Old 06-12-2009, 12:12 PM
It's true. I think I saw a video online of a Toyota Supra with a turbo from a train bolted on it. With enough time and money, you can probably do just about anything.
Picking out a turbo is a giant headache for noobs like me though. I almost think there are too many different turbos out there and I get overwhelmed easily by all of the different options. It seems to me, the decision basically comes down to how much money you have to spend on the entire setup.
