Do all stock WRX clutches have a high engagement point? - Subaru WRX Forum
post #1 of 7 Old 07-27-2014, 03:00 PM Thread Starter
Subarufan123 is an unknown
02-07's specifically, do they all have high engagement points? I've been curious about this for a while and wanted to get opinions. My Bugeye engages 3/4's of the way up from the floor. No signs of slippage what so ever. I've driven several of the newer STi's and WRX's and they all seem to grab 2/4's of the way up from the floor at least.
Subarufan123 is offline
post #2 of 7 Old 07-28-2014, 02:14 PM
arcticscythe's Avatar
the 05 I rebuilt back in High school had a pretty low (like 1/3) engagement point but that was with an aftermarket 6 puck clutch. How many miles are on the current clutch? It could be wearing thin but not failing yet. OEM clutches run for a really long time if you dont beat on them and Ive had 2 cars with clutches that grabbed nicely until they day they didn't grab at all : (
You might want to check the clutch master cylinder, I used to install spacers between the clutch cylinder and the firewall to adjust clutch engagement height when everything is verified and working. I recently adjusted the pedal height on a buddys FRS by backing out the locking nut on the clutch master cylinder and screwing out the pedal yolk ( after disconnecting it from the pedal, DO NOT rotate the clutch master cylinder piston rod). I'm pretty sure the same applies to the 02-07 if you want the engagement height to be lower and to decrease the throw of the pedal a bit.
- Jason
arcticscythe is offline
post #3 of 7 Old 07-28-2014, 06:09 PM Thread Starter
I have 120k on my WRX. Not sure if the clutch was replaced when I bought it at 108k. It catches fine, no slippage, nothing that would worry me. Still has pressure and everything.
post #4 of 7 Old 07-28-2014, 06:11 PM
I bought an 04 WRX new, the engagement point was lower than I expected it to be. In general, Subarus clutch points are low if anything.
post #5 of 7 Old 07-28-2014, 07:35 PM
As long as everything seems to be working you may be able to adjust the clutch pedal position and make it feel better, Is the clutch pedal higher than the brake pedal? someone may have replaced the clutch master cylinder and didn't adjust the pedal, or they may have had it adjusted if the driver was particularly short or had hip problems. If its catching OK and its feels good to you then don't change it, clutch feel is about how you like it, as long as it grabs.
Personally I like it to catch around 1/3 - 1/2 way up the total that way I can feather the clutch without putting strain on my talocalceneal joint,Its particularly sensitive after a long days work (titanium in my ankle from falling off a waterfall)
- Jason
post #6 of 7 Old 07-28-2014, 08:37 PM Thread Starter
Could the heat also effect the clutch at all? I have noticed it gets softer when it gets extremely hot outside. let's say like high 90's.
post #7 of 7 Old 07-28-2014, 08:41 PM Thread Starter
So maybe my clutch is getting worn out?
